rear brake bleeder, oops, I messed up |
dimmer |
May 22 2005, 02:28 PM
Newbie Group: Members Posts: 18 Joined: 22-August 03 From: Oakville, Ontario Member No.: 1,060 |
Went to change my brake fluid today. Started at the back right rear, put some liquid wrench on my bleeder and then turned it... IT SNAPPED RIGHT #$@ OFF.
Not leaking any brake fluid Safe to drive? How am I going to fix this? Any idea would be appreciated. Thanks |
914GT |
May 22 2005, 02:54 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I think you're ok to drive, the piece left inside is still keeping it sealed off. Since there's a hole already in the center of the old screw you could drill it out just enough to use a screw extractor on it. I'd hate to deal with it on the car, I'd most likely take the caliper off and repair it on the bench. But that's me.
McMark |
May 22 2005, 02:57 PM
Joe Bob |
May 22 2005, 03:05 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
Another reason to change fluid on a regular basis....the bleed screws don't freeze up....consider speed bleeders when you replace them.
Eric_Shea |
May 22 2005, 05:06 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
What year is your car? If it's a later model then you should have another. If you broke the bottom one... leave it.
If it's an early model and that's the only bleeder, you're going to need to do a little bench work. There should be a hollow center. You "might" be able to get an extractor in there but before you attempt to turn it, heat the piss out of it with a MAPP or Propane torch. Brakes get hot so you probably won't have any other problems. I doubt if just sticking an extractor in there and calling it a day would work. If all else fails take it to an automotive machine shop and have them drill it and freshen it up with a 7x1 tap. It shouldn't be more than $10 bucks. There are reverse drill bits you may want to try as well. 6mm or 1/4" should do it. |
Lo-Fi Version | Time is now: 8th June 2024 - 07:13 AM |
