> How do I adjust these
ruddyboys
post May 23 2005, 07:39 AM
Hummel eigentümer
OK I always had Webbers so I new how to adjust them. Now I have Dells and how do you adjust them. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Everyone says its like adjusting weber, but they look different. The red circle on the weber is the Air Bypass adjusting screw, while on the Dells it has what looks like a vacuum nipple. The green circle both seem to be the mixture screw? The Dells are recessed and it is hard to get a screw driver in.
Replies(1 - 5)
cgnj
post May 23 2005, 08:09 AM
You are correct.
Carlos
ruddyboys
post May 23 2005, 08:15 AM
Hummel eigentümer
I figured the mixture srew was fine, but what about the red circled nipple, should that be connected to a vacuum hose? My dizzy doesn't have a vacumm connector, if it is for vacuum should it be blocked off
cgnj
post May 23 2005, 08:43 AM
Hi,
Ports for manometer. If snugged no need to be capped.
Carlos
ruddyboys
post May 23 2005, 09:03 AM
Hummel eigentümer
OK but whats a monometer? Can I get a womanometer.
Eric_Shea
post May 23 2005, 09:07 AM
PMB Performance
believe it checks manifold vaccumm pressure.
- Lo-Fi Version Time is now: 31st July 2025 - 06:30 AM
