gas pedal stop, Just a semi hollow plastic bolt? |
Calwaterbear |
Oct 21 2017, 11:57 AM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
rebulding my pedal board, have one original that worked OK as a template, but the stop had some guys rig using a long bolt, nuts and washers etc. In the other example I have the board is completely destroyed, but I was able to extract a plastic boltt from the stop fitting.
In looking at the Haynes Manual, itr appears as this is the original (stock) piece. is that correct? and does it just screw into the nut on the plate - no other hardware? thanks |
GeorgeRud |
Oct 21 2017, 12:47 PM
It’s justaplastic bolt with no locknut. Used to stop the throttle at the full open position, so it’s adjustable.
Calwaterbear |
Oct 21 2017, 03:43 PM
Mikey914 |
Oct 22 2017, 09:40 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
we machined these if you need one
http://shop.914rubber.com/914-Pedal-Stop-A...m?categoryId=-1 Not a great picture but here it is PS also make the stop and the board if you need one Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 07:24 PM |
