Calwaterbear
Oct 21 2017, 11:57 AM
rebulding my pedal board, have one original that worked OK as a template, but the stop had some guys rig using a long bolt, nuts and washers etc. In the other example I have the board is completely destroyed, but I was able to extract a plastic boltt from the stop fitting.
In looking at the Haynes Manual, itr appears as this is the original (stock) piece.
is that correct? and does it just screw into the nut on the plate - no other hardware?
thanks
GeorgeRud
Oct 21 2017, 12:47 PM
It’s justaplastic bolt with no locknut. Used to stop the throttle at the full open position, so it’s adjustable.
Calwaterbear
Oct 21 2017, 03:43 PM
QUOTE(GeorgeRud @ Oct 21 2017, 11:47 AM)
Thanks George, I appreciate the information!
Mikey914
Oct 22 2017, 09:40 AM
we machined these if you need one
http://shop.914rubber.com/914-Pedal-Stop-A...m?categoryId=-1Not a great picture but here it is
PS also make the stop and the board if you need one
