gas pedal stop, Just a semi hollow plastic bolt? |
Calwaterbear |
Oct 21 2017, 11:57 AM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
rebulding my pedal board, have one original that worked OK as a template, but the stop had some guys rig using a long bolt, nuts and washers etc. In the other example I have the board is completely destroyed, but I was able to extract a plastic boltt from the stop fitting.
In looking at the Haynes Manual, itr appears as this is the original (stock) piece. is that correct? and does it just screw into the nut on the plate - no other hardware? thanks |
Lo-Fi Version | Time is now: 17th May 2024 - 09:20 PM |
