can you reuse presure plate bolts |
flmont |
Oct 21 2017, 12:19 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
when I pulled the PP bolts they were not torqued very tight, nor did they have any type of lock tight on them So I am hoping I can..?? Thanks Frank
mepstein |
Oct 21 2017, 01:02 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’m pretty sure on a 4 you can but not on a 6. There was a thread 6-12 months ago.
porschetub |
Oct 21 2017, 01:33 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yes you can ,but why...cheap enough to buy,I use high-tensile capscrews done up to the correct torque no issues.
No harm in putting a little Loctite on them. |
saigon71 |
Oct 21 2017, 01:38 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
If the bolts weren't damaged by not being fully torqued, I'd reuse them. If a visual inspection reveals any damage, replace them,
flmont |
Oct 21 2017, 01:54 PM
I think the P.O. had kinda mocked up the clutch but didnt torque.
McMark |
Oct 22 2017, 07:08 AM
Mark Henry |
Oct 22 2017, 07:25 AM
I’m pretty sure on a 4 you can but not on a 6. There was a thread 6-12 months ago. You're thinking of flywheel bolts. PP bolts are just M8 bolts, and the final torque value isn't high. So go ahead, as long as they aren't damaged or otherwise compromised. (IMG:style_emoticons/default/agree.gif) Because such a large diameter surface area of the PP mounting face the M8 bolts don't see much stress and are OK to reuse. The /6 flywheel bolts are suppose to stretch like rod bolts, so it's recommended to replace, personally I think it's BS but for $10-15 worth of bolts I don't chance it. |
McMark |
Oct 22 2017, 07:44 AM
The /6 flywheel bolts are suppose to stretch like rod bolts, so it's recommended to replace, personally I think it's BS but for $10-15 worth of bolts I don't chance it. (IMG:style_emoticons/default/agree.gif) |
mepstein |
Oct 22 2017, 08:40 AM
I’m pretty sure on a 4 you can but not on a 6. There was a thread 6-12 months ago. You're thinking of flywheel bolts. PP bolts are just M8 bolts, and the final torque value isn't high. So go ahead, as long as they aren't damaged or otherwise compromised. (IMG:style_emoticons/default/agree.gif) I was mixed up as usual. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:38 AM |
