JFG |
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None ![]() |
I have a set of riviera alloys which i am thinking of fitting. I've seen some cars fitted with them in pictures only.
As i hadn't touched them since i bought them over a year ago i thought i'd give them a clean and good check over. When i measured the offset i calculate it as being et20! Standard fitment on a 914 is et40. So my question is how do they fit? If i put a spacer on i'm just going to push the tyres into the fenders. Have i bought the wrong size set? |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,323 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
They don’t typically work well with wider tires. More of a VW wheel than 914.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
You can likely run 165-width tires on them. Wider is pretty certain to rub, unless you've got flared fenders.
--DD |
JFG |
I've found a set of fuch replicas. They are 5 1/2j et35. to enable a tyre choice what is the fitment gping to be like? Stovk fenders.
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
I have Riviera wheels on my "75 and I fitted 195/65R15s after rolling quarters on mine. I know a lot of people don't like the Rivieras, but I think they look good.
For some reason I can't add a photo... (IMG:style_emoticons/default/confused24.gif) |
JFG |
I like the look of rivieras that's why i bought them. If i can find a matching 4th over here i'll stick with them.
Dave_Darling |
The Rivs were made in several different offsets. The ones intended for Bugs will not fit wider tires under 914 fenders. The ones intended for 914s will.
--DD |
larryM |
emoze ![]() ![]() ![]() Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California ![]() ![]() |
(IMG:style_emoticons/default/cheer.gif) use this calculator - http://www.rimsntires.com/specspro.jsp |
Lo-Fi Version | Time is now: 16th June 2024 - 02:19 AM |
