Rust repair, Ramp |
Rust repair, Ramp |
lcato |
May 24 2005, 01:23 PM
Newbie Group: Members Posts: 6 Joined: 15-May 05 From: Delmar NY Member No.: 4,081 |
I'm thinking of building this ramp to aid in my rust repairs.
Any suggestions. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Attached image(s) |
SirAndy |
May 24 2005, 02:35 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
that looks like it could work ...
any info on the materials used? (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Andy |
Mueller |
May 24 2005, 02:39 PM
depends on the repairs...you might want to support the vehicle more closer to the "doughnuts" underneath....
sharper |
May 24 2005, 03:02 PM
Member Group: Members Posts: 146 Joined: 5-June 03 From: Woodstock, GA Member No.: 789 Region Association: South East States |
How high up does that get the car? I have mine up on 4 auto ramps that you can get anywhere and have no problem rolling around under it on a creaper. Everything is easily accessible since the only area blocked by the ramps are the tires.
TravisNeff |
May 24 2005, 03:18 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Have you access to a welder or a buddy that can weld? That would seem like doing it in steel with some heavy duty swivel casters would be less effort, moveable and be able to tie to your jack points. Square tube stock, angle stock, casters and some metal plate.
I had a set of ramps made by my buddy a looong time ago out of huge sections of wood. Worked great as the ramps were very long to help out with a lowered car and a little "U" shape for the tires to set in. |
lcato |
May 24 2005, 04:14 PM
I plan to make it from 2x12 lumber. I will make it 12inches off the ground.
The "doughnuts" are rusted. I have a mig welder but wanted to use wood because it would strong, cheap and light. With the removable ramp and center sections, I can roll the car up and then remove those sections. It's the same idea as using 4 ramps but easier to rise. |
Lo-Fi Version | Time is now: 3rd June 2024 - 05:19 AM |
