boston914 |
Member ![]() ![]() Group: Members Posts: 52 Joined: 15-July 03 From: Boston, MA Member No.: 912 ![]() |
My parking brake holds fine, but when I release it, it seems like the caliper is not retracting properly.
I get a chirping sound from the Left Rear caliper when I drive the car. Question: Would this indicate a bad caliper, or could it just be a problem with the parking brake cable? Any help would be greatly appreciated. _________________________________ '76 Malaga Red |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
pull the wheel, have someone engage the PB, then watch the caliper when they disengage it... it *COULD* be the cable, but it could just be the spring on the caliper...
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
It can also be goo inside the caliper hanging up the mechanism, which means a caliper rebuild. I've also had the pin that tensions the spring on the caliper break off.
tat2dphreak |
yep... Eric Shea told how to fix that... drill it out (can't remember the diameter of the drill bit) then put JBweld in the hole, and break the bit off(use the broken drill bit as the new pin) |
meares |
Member ![]() ![]() Group: Members Posts: 403 Joined: 23-March 05 From: Atlanta Member No.: 3,800 ![]() |
where can i find an emergency brake handle? the folding one?
tat2dphreak |
don't get a folding one... get a later style.. the folding(early style) is a piece of shit!
put a WTB in the classifieds here... there are plently of people parting cars... |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Why is the folding one a POS? When I bought my new '73, it had the retracting (folding) parking brake handle that you never got hung up on when entering/exiting the car. The non-retracting (non folding) one (like in my '75) sits up where you can't help but bump it when getting in and out of the car. I liked the folding one much better. I would think POS would be the other way around, unless there's something I'm missing??? Andy |
tat2dphreak |
if the folding one is in good shape, they are usually fine, but 9/10 of them are in bad shape and they have an interior piece that can't be replaced anymore... the later style is much better, even if it gets in your way sometimes... the later style handle doesn't fail, and the parts are available to fix them if for some reason they do... |
Lo-Fi Version | Time is now: 11th July 2025 - 05:20 AM |
