Windshield Wipers, Radio, Not Working |
stevend914 |
Nov 5 2017, 08:44 AM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
So I had problems when arriving NC with the wipers not working and then later in the day working, same with radio. I had replaced the fuses and I just replaced all the relays. Still not working, rechecked fuses and they are OK. Not sure what else to check.
Dave_Darling |
Nov 5 2017, 01:09 PM
Multimeter time... Dig that out and the wiring diagram and have at it.
--DD |
burton73 |
Nov 5 2017, 06:13 PM
burton73 Group: Members Posts: 3,534 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
It may be the connection of the relays. I cleaned them and the sockets with a contact cleaner and spread the relay posts a little and it fixed it right up. I had no horn as well and they all came back up. No wipers, horn, radio. Fixed them right up.
Bob B |
stevend914 |
Nov 7 2017, 11:04 AM
Loose connection at the fuse panel.
9fourteen14 |
Dec 2 2017, 12:07 PM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
So I had problems when arriving NC with the wipers not working and then later in the day working, same with radio. I had replaced the fuses and I just replaced all the relays. Still not working, rechecked fuses and they are OK. Not sure what else to check. Steve, this almost sounds like my problems/WIRES.... BUT i know my wires need to be replaced.. they are burned to hell. 74 914 2.0 what are you finding? |
Tbrown4x4 |
Dec 2 2017, 04:12 PM
Senior Member Group: Members Posts: 704 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
I just had a loose relay behind the fuse panel cause the same thing. All I noticed was no wipers and the defrost switch backlight didn't work. I don't have a radio.
Coondog |
Dec 2 2017, 04:33 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Install the J West fuse panel and all your troubles will go away........ (IMG:style_emoticons/default/huh.gif)
76-914 |
Dec 2 2017, 08:16 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Install the J West fuse panel and all your troubles will go away........ (IMG:style_emoticons/default/huh.gif) It will cure the loose fuse syndrome but if you don't have loose fitting fuses causing bad a bad connection keep looking. If you have a JWest use the fuses that light up when they blow. Easy to spot the blown fuse and you won't need an ohm meter to find which fuse blew. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 28th May 2024 - 07:30 PM |
