Is there a tool, that gauges wires, |
flmont |
Nov 6 2017, 11:20 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
Being that I will need to build a fuse and relay panel for my Subie build,is there a tool that gauges wires so I can match my harness wires to new panel/fuse/relay wires,.?? Thanks Frank
raynekat |
Nov 7 2017, 12:21 AM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Can buy one of these almost anywhere....
flmont |
Nov 7 2017, 12:41 AM
Ah sweet,..thank you raynekat.!!
76-914 |
Nov 7 2017, 02:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You'll get very close with that. Porsche and Suby are Metric but most places you buy wire will not be metric anyway. I've had good luck with these folks. https://www.wirebarn.com/Wire-Calculator-_ep_41.html (IMG:style_emoticons/default/beerchug.gif)
JeffBowlsby |
Nov 7 2017, 02:28 PM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Being that I will need to build a fuse and relay panel for my Subie build,is there a tool that gauges wires so I can match my harness wires to new panel/fuse/relay wires,.?? Thanks Frank The factory schematics for the later model years include wire gauges for each circuit. That work is done for you. |
Dave_Darling |
Nov 7 2017, 04:58 PM
Note that the insulation thickness can vary from manufacturer to manufacturer. The conductor is the important part, and that's what should be measured. That's what the factory diagrams call out, I believe, is the conductor diameter in millimeters.
Presumably the AWG too also measures wire size, not insulation size. --DD |
Mueller |
Nov 7 2017, 05:29 PM
Note that the insulation thickness can vary from manufacturer to manufacturer. The conductor is the important part, and that's what should be measured. That's what the factory diagrams call out, I believe, is the conductor diameter in millimeters. Presumably the AWG too also measures wire size, not insulation size. --DD I believe the Porsche diagrams are in mm² ? |
GeorgeRud |
Nov 7 2017, 08:49 PM
The factory does use the mm designations, but here’s a conversion chart.
Dave_Darling |
Nov 7 2017, 09:30 PM
Lo-Fi Version | Time is now: 31st May 2024 - 09:34 PM |
