| gms |
Nov 7 2017, 09:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,738 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest
| db9146 |
Nov 7 2017, 09:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None
Wow, how many 914-6s have you dismembered?
| GeorgeRud |
Nov 7 2017, 09:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
They can help with oil filters on 914-6 or 911s as well.
| porschetub |
Nov 7 2017, 10:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,065 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Wow $$$$ worth are reuseables....I think they are great ,is that what the original hoses used ?,seen a few NOS '6" hoses and they were crimped connectors reason for asking.
(IMG:style_emoticons/default/beer.gif) . |
| IronHillRestorations |
Nov 8 2017, 06:28 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,927 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
More of Stazak showin' off (IMG:style_emoticons/default/smile.gif)
| gms |
Nov 8 2017, 10:26 AM
I have several 914/6s so I removed them as I feel the hose becomes too old and brittle. This is what the original set looks like, I am not aware of any original lines that were crimped.
| gms |
Nov 8 2017, 10:28 AM
this is a close-up of the aluminum ends
| gms |
Nov 8 2017, 10:43 AM
I have a car that came with this elbow (used on the race cars)
| mepstein |
Nov 8 2017, 11:07 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Glenn - I could vapor blast those aluminum fittings for you. It would remove any corrosion without removing metal or markings. Would look almost new (except for scratches) when done. If you want to try a couple pieces, let me know.
I can do the steel ones and clean them up but you would need to have them plated or the bare metal will rust. Attached image(s)
| gms |
Nov 9 2017, 12:16 PM
Glenn - I could vapor blast those aluminum fittings for you. It would remove any corrosion without removing metal or markings. Would look almost new (except for scratches) when done. If you want to try a couple pieces, let me know. I can do the steel ones and clean them up but you would need to have them plated or the bare metal will rust. Thanks for the offer but I already have a local source |
| 914 |
Nov 9 2017, 03:12 PM
Senior Member ![]() ![]() Group: Members Posts: 468 Joined: 26-December 02 Member No.: 19 Region Association: Southern California
Glen,
Are the hose couplings compression fit? 914/Alan |
| gms |
Nov 9 2017, 03:57 PM
| bretth |
Nov 9 2017, 04:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I never knew that they came apart for reuse. Was going to throw mine away, glad i didn't.
| gms |
Nov 10 2017, 11:26 AM
I never knew that they came apart for reuse. Was going to throw mine away, glad i didn't. you can send a reward to me (IMG:style_emoticons/default/biggrin.gif) |
| johnhora |
Nov 10 2017, 02:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 902 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
Stoddard sells both sizes of the OEM style hose to go with these...
| gereed75 |
Nov 10 2017, 07:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
Wish I would have known that. Gave my originals away.
Lo-Fi Version | Time is now: 2nd April 2026 - 03:27 PM |
