External Oil Cooler Identification of Part, What is this? My fan stopped working |
LukeD |
May 25 2005, 07:28 PM
Member Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None |
My external oil cooler fan stopped working. Does anyone know what this is or where to start?
PO put the cooler and fan on and it mysteriously stopped working. I checked the 2 fuses that are attached to wires that attach to this, both good (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) I have the car on stands letting it cool off before I start the troubleshooting. Can I just bypass this box and have it run all the time with the car on? It's getting damn hot here anyway, atleast for the summer. Luke D Attached image(s) |
LukeD |
May 25 2005, 07:38 PM
The circled wire goes into the box.
Attached image(s) |
LukeD |
May 25 2005, 07:41 PM
What I don't understand is why it takes 5 wires plus the gray wire which must be some sort of temp sensor since it goes into the fins of the cooler. So 6 wires to run a fan??
LukeD |
May 25 2005, 07:49 PM
Looks like my system is very similar to the pelican tech article. I know have a better understanding of what he has done. Won't know for sure until I crawl under there with flash light
Luke D |
Demick |
May 25 2005, 07:50 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
It's a thermostat. Do a google search for:
thermostat 70085 and you'll find it. Demick |
Aaron Cox |
May 25 2005, 07:52 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
where does it take its oil from?
not the sandwhich adapter..... does it take it off an oil cooler adapter plate/spacer? |
LukeD |
May 25 2005, 08:20 PM
There are 2 lines comming from just above the oil filter. Looks like a sandwich adapter that screws onto teh factory filter location and the filter screws onto that. They go straight to the cooler unlike that pelican article.
Luke D |
LukeD |
May 25 2005, 08:29 PM
Found a picture but no diagram for where the wires go. Ugg |
LukeD |
May 25 2005, 10:50 PM
!! UPDATE !!
Problem fixed. I traced all the wires and found the main + lead barely hanging on by a thread. Re-crimped and fan comes on at 200F. One thing I noticed is the fan is pulling air down, is this correct? Second, I think I am going to have to put in a relay to power the fan cause I doubt that the thermostat is going to last with the main power running through it. Third, I notice that if I post a new thread that it motivates me to fix the problem and I end up answering my own questions LMFAO (IMG:http://www.914world.com/bbs2/html/emoticons/chair.gif) Thanks for the motivation dear 914club (IMG:http://www.914world.com/bbs2/html/emoticons/wub.gif) Luke D |
ArtechnikA |
May 26 2005, 06:13 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
'correct' is going to be relative in this case. your cooler is located behind the engine, next to the transmission, and above the heat exchanger. you definitely do NOT want to be blowing hot air off the heat exchanger up into the cooler, so down is better. but there's not much room above the cooler for air to enter; that's got to be hurting your efficiency still more. longer spacers, maybe? to address the "how many wires does it take" question in the thread, 6 seems right: power and ground in, two leads from the thermostat, + and - to the fan motor. |
Lo-Fi Version | Time is now: 3rd June 2024 - 08:37 AM |
