It works, Interior light |
Coondog |
Nov 20 2017, 04:52 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Light never worked, so last year I changed the bulb out to LED thinking that was it.
Of course I cracked the FNNN lens and the light still didn’t work.... (IMG:style_emoticons/default/headbang.gif) Today I opened the door and saw the light flicker (IMG:style_emoticons/default/smile.gif) Took out the door switch, cleaned up the contacts and WOOHOO!!! it works. |
GeorgeRud |
Nov 20 2017, 05:18 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I also replaced the fastoon bulb with a LED bulb, but it does run hot (though it is bright) I was hoping that the LED bulb would be cooler than the incandescent one I replaced. If yours stays cool, please let us know what bulb you bought.
GeorgeRud |
Nov 20 2017, 05:20 PM
Coondog |
Nov 20 2017, 05:36 PM
I used the same bulb.
914_teener |
Nov 20 2017, 05:42 PM
914 Guru Group: Members Posts: 5,200 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I used the Dorman replacement LED. It runs cool and bright.
Keep in mind it runs off a switched ground from the door switches as the OP found out. These are NLA and are commonly worn out especially on the drivers side. |
porschetub |
Nov 21 2017, 01:26 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Used the same LED...huge difference,how hot do they get ?,hopefully not enough to melt the lense (IMG:style_emoticons/default/confused24.gif) . |
bbrock |
Nov 21 2017, 03:05 PM
Keep in mind it runs off a switched ground from the door switches as the OP found out. These are NLA and are commonly worn out especially on the drivers side. Isn't it just this: http://www.pelicanparts.com/More_Info/1139...113-947-561-INT (IMG:style_emoticons/default/confused24.gif) |
914_teener |
Nov 21 2017, 11:30 PM
If you use those you'll have rewire and splice the wires.
They are not plug and play and they don.t fit very well. |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:03 AM |
