Looking for second opinion about synchro rings |
draganc |
Nov 20 2017, 11:54 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Tbrown4x4 |
Nov 21 2017, 05:37 AM
Senior Member Group: Members Posts: 705 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
OK. Just for shits and giggles, I'm going to throw this out there so Dr. Evil can pipe in with the correct answer.
Not being totally familiar with German syncros, I'm going to guess "A" is fairly worn, (possibly 2nd gear?). The rest look serviceable to me. I might move "A" to 4th or 5th, and move a nicer one to second, where it has to work harder. If these were cheap enough, I would replace them all, but 3 of them look great to me as is. Flame away, Gents! I put my ignorance on the table for all to see. (IMG:style_emoticons/default/smile.gif) |
McMark |
Nov 21 2017, 07:02 AM
A is the worst of the bunch and I wouldn't put it on 1-2-3 gears. But it would work fine for 4-5. B-C-D are all a bit worn, but look like they've been replaced fairly recently. Compare them to the four completely unusable synchros I just pulled out of a box I'm rebuilding. Especially notice that yours are all still black, and these junkers are mostly grey. And the profound grooves worn in three of them. Attached thumbnail(s) |
John |
Nov 21 2017, 07:14 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
(IMG:style_emoticons/default/agree.gif) A is the worst of the bunch and I wouldn't put it on 1-2-3 gears. But it would work fine for 4-5. B-C-D are all a bit worn, but look like they've been replaced fairly recently. Compare them to the four completely unusable synchros I just pulled out of a box I'm rebuilding. Especially notice that yours are all still black, and these junkers are mostly grey. And the profound grooves worn in three of them. I agree that A is worn. However, in a pinch, one could flip it over and use the un-worn side toward the slider. If it were me, I would replace, but if it were me 20 years ago, I would have used it flipped on 4th or 5th. The others appear (and sometimes appearances can be deceiving) ok. It's hard to tell from pictures. You also need to consider the condition of the sliders and the teeth. Good luck with it. |
ChrisFoley |
Nov 21 2017, 07:38 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The gap on A also looks a little smaller. A brake band which has collapsed noticeably isn't worth re-using even if the friction surface looks acceptable.
get off my lawn |
Nov 21 2017, 06:11 PM
Member Group: Members Posts: 168 Joined: 18-August 11 From: west coast Member No.: 13,462 Region Association: None |
LOL.
draganc |
Nov 21 2017, 07:22 PM
Thank you for your inputs fellas!
(IMG:style_emoticons/default/beerchug.gif) and Happy Thanksgiving! |
Dr Evil |
Nov 22 2017, 01:41 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Fun post, and I agree with all the above. A could easily be used in 4 or 5 if flipped to allow the rough side to be the contact surface. Depending on your budget and time, no need to replace any of those if you verify they are not collapsing as mentioned.
914forme |
Nov 23 2017, 11:08 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
The gap on A also looks a little smaller. A brake band which has collapsed noticeably isn't worth re-using even if the friction surface looks acceptable. Chris, I think that is just the hand holding the bands. Stack them on a flat surface, take a straight edge line them all up, and see if any of them are smaller than the others. If not, go with what the others have said. If yes, then replace the collapsed one(s). |
Lo-Fi Version | Time is now: 6th June 2024 - 10:42 PM |
