HARD brake pedal, As in... does not move |
poorsche914 |
Nov 25 2017, 06:55 PM
T4 Supercharged Group: Members Posts: 3,090 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Background: Barn find '72 1.7 that PO bought in May 2016. He had brake work done (not exactly sure what all was done) along with a few other minor items to get roadworthy. The car was rarely driven during his ownership. In fact, it quit running in early spring 2017 (vacuum leaks, among other issues). PO was NOT mechanically inclined and had others do all work.
I bought the 914 early summer of this year and it has mostly been sitting in my driveway as I slowly sort through various issues. I sorted through the fuel system, vac lines, etc and got the 1.7 to fire up and run. Took it for a drive around the subdivision. Ran but not great. Still more work to do. (IMG:style_emoticons/default/dry.gif) Currently: So it sat a bit more and when I did finally get back to it, went to take it for another test drive and noticed the brake pedal is now VERY hard as in, barely moves. (IMG:style_emoticons/default/blink.gif) Any ideas on what may have happened from one drive to the next? Could it be something as simple as pedal bushings needing replaced? Or could it be MC or something else in the brake system? Seems odd that pedal was fine one day and then a few weeks later, without touching it, it barely moves. (IMG:style_emoticons/default/driving.gif) |
IronHillRestorations |
Nov 25 2017, 07:11 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
My guess is you have a bad master cylinder that has leaked brake fluid on to your original plastic pedal cluster bushings that have expanded and bound up your pedal.
mgphoto |
Nov 26 2017, 05:53 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Bushings in the pedal assembly are swollen, get a rebuilt unit from Bruce Stone, member here, too notch work.
Lo-Fi Version | Time is now: 23rd May 2024 - 12:43 AM |
