SOT: Electronics question for welder repair, Capacitor close enough? |
bbrock |
Nov 28 2017, 10:17 AM
While replacing the diodes on my Hobart Handler MIG last week, one of the leads popped off of one of the little capacitors attached to diodes for protection. Googling, I found advice saying the exact value of those capacitors is not important and to just get "something close." But no indication of what close enough would be. The factory part is 0.01uF, 100v. Digging through my spare components, I found, and installed a 0.3uF, 100v capacitor (I do have 0.01 uF but only 25v). After the repair, the welder is working like new.
But I'm wondering if that substitute capacitor is sufficiently protecting the diode. Getting the correct capacitor is easy enough, but digging into the welder to replace it is not. I'd like to call the repair done, but don't want to burn up my new diode. Thoughts? |
Spoke |
Nov 28 2017, 11:17 AM
Jerry Group: Members Posts: 6,985 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Not sure a 0.3 is close to a 0.01 since it is 30x larger.
You can order one of the correct value from Digikey. |
bbrock |
Nov 28 2017, 11:29 AM
Not sure a 0.3 is close to a 0.01 since it is 30x larger. You can order one of the correct value from Digikey. Thanks, That's kind of what I suspected. Although I understand the basics of how capacitors work, it is a bit of a mystery to me how they work to protect circuits in this type of application. So I wasn't sure if 30X would be significant. Do these capacitors smooth the current running through the diode? Better safe than sorry I guess. I'll check the local Radio Shack tomorrow, and if they don't have it, I'll order from Digikey or Jameco. |
Spoke |
Nov 28 2017, 12:15 PM
Capacitors are often used in circuits as "snubbers". That is it snubs or knocks down transient voltages across components like diodes. A real high transient voltage on a diode can destroy it in microseconds.
bbrock |
Nov 28 2017, 12:28 PM
Capacitors are often used in circuits as "snubbers". That is it snubs or knocks down transient voltages across components like diodes. A real high transient voltage on a diode can destroy it in microseconds. Ah! Makes sense. Thanks! (IMG:style_emoticons/default/beerchug.gif) Gotta protect my $24 apiece diodes!!!! |
Lo-Fi Version | Time is now: 23rd May 2024 - 11:53 AM |
