pulling and replacing throttle cable, through the front, or back? |
Calwaterbear |
Dec 1 2017, 09:24 AM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
Ok so i have to replace the throttle cable, so do I pull it from the rear - through the firewall, or would you pull it out from the front - in the cabin out ther front of the tunnel?
and would it be beneficial to tie on a small chaser wire, then leave it in place, to use to pull the replacement? |
JFG |
Dec 1 2017, 09:26 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
Mine came out of the rear, eventually. The new one went in from the rear. No chaser needed.
clapeza |
Dec 1 2017, 10:02 AM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
Yes, it just pulls out from the firewall side.
It can't be emphasized enough, do not tie or attach anything to the old cable. The tube is pretty tiny, and anything attached will create more headaches when it gets wedged inside. The new cable should feed freely all the way to the front under its own inherent stiffness. Some have recommended using a light spray lubricant to help it pass, but that tube is about 4 feet long, so bear that in mind. |
iankarr |
Dec 1 2017, 10:43 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,477 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Feed the tube lots of White Castle hamburgers and tequila. After that, it'll pass anything. (IMG:style_emoticons/default/wink.gif)
Lo-Fi Version | Time is now: 23rd May 2024 - 06:10 AM |
