engine shrouds, Hallowe'en...NOT...are all shrouds essentially interchangeable |
porbmw |
Dec 1 2017, 02:37 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
"someday" I plan on installing a 2.7 engine in the engine compartment of an engineless original 6
What engine shroud "fits" the 2.7? can/do/should I use a shroud from a 6/or early 2.0/2.2/2.4 engine, or does the 2.7 engine require a shroud specifically from a 2.7 IF so, is there a "shroud color difference" from one 2.7 to another and..if so...which is preferred Thanks Paul |
douglastic |
Dec 1 2017, 03:31 PM
not a real person Group: Members Posts: 58 Joined: 7-November 16 From: Beaumont, CA Member No.: 20,566 Region Association: Southwest Region |
"someday" I plan on installing a 2.7 engine in the engine compartment of an engineless original 6 What engine shroud "fits" the 2.7? can/do/should I use a shroud from a 6/or early 2.0/2.2/2.4 engine, or does the 2.7 engine require a shroud specifically from a 2.7 IF so, is there a "shroud color difference" from one 2.7 to another and..if so...which is preferred Thanks Paul This isn't your missing engine, is it? http://www.914world.com/bbs2/index.php?showtopic=320513 |
porschetub |
Dec 1 2017, 03:48 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
"someday" I plan on installing a 2.7 engine in the engine compartment of an engineless original 6 What engine shroud "fits" the 2.7? can/do/should I use a shroud from a 6/or early 2.0/2.2/2.4 engine, or does the 2.7 engine require a shroud specifically from a 2.7 IF so, is there a "shroud color difference" from one 2.7 to another and..if so...which is preferred Thanks Paul Someone is welcome to correct me but from memory the design changed for the 2.7,it may have something to do with the CIS and cooling fan size (IMG:style_emoticons/default/confused24.gif) ,the cooling duct for the oil cooler was changed from memory. I would tend to buy one that was supplied for your motor,you should pick one up for reasonable money,folks steer away from damaged ones but they can be easily repaired if cleaned properly before hand. Early 2.7 (74) were black and the later ones green gelcoat. |
johnhora |
Dec 1 2017, 03:50 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
911 engine shrouds....
914-6 used the one listed as 2.2T |
Larmo63 |
Dec 1 2017, 03:52 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
sithot |
Dec 1 2017, 04:13 PM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
http://www.series900.com
Damon makes all the correct colors. Early red is different than later red. 911SC is red-orange. You can get clear too and I suspect for the right price he'll make one any color you want. These have the color incorporated into the mold, not painted. |
porbmw |
Dec 1 2017, 04:38 PM
"someday" I plan on installing a 2.7 engine in the engine compartment of an engineless original 6 What engine shroud "fits" the 2.7? can/do/should I use a shroud from a 6/or early 2.0/2.2/2.4 engine, or does the 2.7 engine require a shroud specifically from a 2.7 IF so, is there a "shroud color difference" from one 2.7 to another and..if so...which is preferred Thanks Paul This isn't your missing engine, is it? http://www.914world.com/bbs2/index.php?showtopic=320513 I wish I knew. I was about to see if I could get a Certificate of Authenticity, but have just read here on "TheWorld" that as of this year I need to know the original engine number. The car came to me without that info...I will see if I can track down a previous owner, to see if that info exists "somewhere" |
porbmw |
Dec 1 2017, 04:41 PM
Thanks to all!
A wealth of info out here in "theworld"! Would have been quite the task for me to figure out! (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:21 AM |
