FS-901 Side shift transaxle $500 |
Lunatic |
Dec 2 2017, 04:00 AM
Newbie Group: Members Posts: 2 Joined: 31-January 17 From: Kitchener, Ontario, Canada Member No.: 20,797 Region Association: None |
Transaxle removed from a 75 Porsche 914
Complete with axles, speedo cable, and clutch This is the side shift version Date code: HA08034 (March 08 1974) $500 located in Kitchener, Ontario, Canada. Note: This transaxle was removed from a running 914. Mileage is unknown. I was going to use this transaxle behind a Northstar V8 project. In the making of my adapter plate, I also had to remove some material by the starter nose for clearance. You can clearly see the hole that I had to make. I also have two used clutches that you can have. Shayne Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 06:09 PM |
