mmichalik |
MikeM ![]() ![]() ![]() Group: Members Posts: 706 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California ![]() ![]() |
I'm looking for a fender that is in good shape. I'm more interested in the rear half of the fender so, if it has damage up front, I'm ok with that.
Please let me know if you have one. Thanks! Mike |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I have a Stratocaster with a warped neck, but the other part is ok.
Seriously, a little info might get the real thing you are hunting. Like front or rear? |
mmichalik |
I have a Stratocaster with a warped neck, but the other part is ok. Seriously, a little info might get the real thing you are hunting. Like front or rear? Thanks but, I like my 1949 Martin 0016 (IMG:style_emoticons/default/smile.gif) I was working under the assumption that fenders are typically removable and in the front, quarter panels are in the rear and not usually easily removable. If that's not how it works on a 914, than please correct me if I'm wrong. So, to clarify, I'm looking for a passenger side front fender for my '75. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I have a Stratocaster with a warped neck, but the other part is ok. Seriously, a little info might get the real thing you are hunting. Like front or rear? Thanks but, I like my 1949 Martin 0016 (IMG:style_emoticons/default/smile.gif) I was working under the assumption that fenders are typically removable and in the front, quarter panels are in the rear and not usually easily removable. If that's not how it works on a 914, than please correct me if I'm wrong. So, to clarify, I'm looking for a passenger side front fender for my '75. Thats true of 911's but 914's are spot welded, front and rear. |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
I have this good fender. I am willing to cut it down to the size you need. The areas that is missing paint was done by me making sure there were no rust issues there and there isn't.
Attached image(s) ![]() ![]() ![]() ![]() |
mmichalik |
PM sent
GaroldShaffer |
More pictures
Attached image(s) ![]() ![]() ![]() |
mmichalik |
GaroldShaffer |
I cleared off a bigger area of paint on my fender, it is solid. The underside is solid also I sent you a PM. (IMG:style_emoticons/default/beer.gif)
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 17th June 2024 - 03:57 AM |
