1975 2.0 Engine Swap, Parts list for installation of replacement and suggestions/guidance |
walter j |
Dec 19 2017, 02:25 PM
Newbie Group: Members Posts: 8 Joined: 15-November 11 From: New York Member No.: 13,790 Region Association: None |
First of all, my apologies if this is the wrong place to post this or if what I am looking for has already been done elsewhere.
I have a 1975 2.0 and intend to swap the engine and replace it with a 1.7 engine from a 1972 914 that has been rebuilt by Kelly Moss to what I think is 2056. I plan on using the Weber carbs (44 IDF), exhaust and mechanicals that are currently mounted on the 72 in the 75 unless there's a reason not to (please chime in). The engine in the 75 is in need of a rebuild and this car turned up on BAT recently and caught my interest so that’s the project. I have found posts about removing the engine, etc. but I was hoping to find a post/thread that goes through all of the rubber and other parts that should be replaced when installing the replacement engine. To the extent there are related things to address while the engine is out, I would be interested to hear those suggestions. I will see what the clutch looks like when the engine is out. I am going to be working on this project with a mechanic friend of mine so I am trying to get as much done ahead of time to make the job easier on his part since beer and pizza will only go so far. Thanks for the group think and patience since I have not taken on a project of this scope before and it took me a long time to get here. |
barefoot |
Dec 20 2017, 04:59 PM
Senior Member Group: Members Posts: 1,281 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
The engine tin bits will all be OK, but you will need all the exhaust system parts from the 1.7 including the heater duct parts as that stuff is different from 75-76 versions.
Look at the exhaust sections of the attached PET diagrams. 914petE.pdf ( 3.58mb ) Number of downloads: 191 |
walter j |
Dec 21 2017, 09:27 AM
The engine tin bits will all be OK, but you will need all the exhaust system parts from the 1.7 including the heater duct parts as that stuff is different from 75-76 versions. Look at the exhaust sections of the attached PET diagrams. 914petE.pdf ( 3.58mb ) Number of downloads: 191 Ok, I will check that out as we move along. Thanks for the input. |
Lo-Fi Version | Time is now: 8th June 2024 - 08:33 AM |
