Master Cylinder Replacement, Master Cylinder Replacement question |
dralf |
Dec 31 2017, 01:18 PM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
Once the weather gets a bit warmer in Ohio I plan to replace my worn out master brake cylinder with a new ATE unit. My question to the group is do I need to "Bench Bleed" the unit before installing it ? I recall having to do something like that on a Honda Civic. If that is an operation that is necessary, where can I find info on how best to accomplish that, or will the MC unit purge itself as I bleed the brakes ?
fixer34 |
Dec 31 2017, 03:08 PM
Senior Member Group: Members Posts: 1,087 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Once the weather gets a bit warmer in Ohio I plan to replace my worn out master brake cylinder with a new ATE unit. My question to the group is do I need to "Bench Bleed" the unit before installing it ? I recall having to do something like that on a Honda Civic. If that is an operation that is necessary, where can I find info on how best to accomplish that, or will the MC unit purge itself as I bleed the brakes ? Skip the ATE unit and get one from Mikey at 914rubber. Spend the extra couple bucks for the 'ez install' option. |
Mikey914 |
Dec 31 2017, 03:51 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Bench bleeding is a process of pumping the bubbles out of the MC.
https://www.wikihow.com/Bleed-a-Master-Cylinder Generic but you get the idea |
Lo-Fi Version | Time is now: 8th June 2024 - 05:28 PM |
