JFG |
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None ![]() |
I have modified the tinware which covers the cylinders and heads and now I need to make the tin pieces to fit in front of the cooling fan. My problem is that as I have to make this from scratch I don't know how it fits, especially around the cooling fan and alternator.
I also have an issue with the passenger side e-brake cable. How does this sit in relation to the engine bar? Does it rest between the bar and chassis mount or does it sit up against the chassis mount? Finally, I am looking for the cleanest way to run the fuel pipe up to the carbs and how best to sit the pipe across the engine to connect both carbs. I've seen various images of this but differences exist and I'd like to know why. Twin Weber 40 IDF set up with csp bellcrank linkage. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,008 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
the front engine tin pieces should be very cheap... (just expensive to ship)
are you sure its not worth buying a couple of used pieces for sale? I've seen a lot of different routing for carbs/fuel some use a return others do not technically a return is the better way and at least helps with cooling of the fuel enough to aid in vapor lock I will look for an old diagram of different routings to link to your thread brant |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The engine tin should be pretty straightforward to get a photo or six of. Just use Google Images.
The E-brake cable should run on the underside of the trailing arm, I believe. The carb fueling setup is pretty much however you want to do it. Most people seem to just run some fuel hose and let it lie where it wants or zip-tie it to stuff that's nearby. A minority will fab up a cross-over pipe, bead the ends, and run short hoses from the carb bodies to the cross-over. --DD |
brant |
Attached image(s) ![]() |
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,721 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
nevermind
JFG |
I tried to buy the tinware before but seller never came back to me.
I've found pics of the tinware from above and slightly up from side view but nothing from underneath. Anyone post one up? |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Can you take pictures of the tin mods you've made? The stock one is comprised of 2 pieces.
Lo-Fi Version | Time is now: 3rd July 2025 - 10:56 PM |
