Raleigh NC Looking for a repair shop Djet specialist, 2.0l 75 914 |
rfinegan |
Jan 19 2018, 09:13 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I need to find a shop that can work and repair a 2.0 Djet.. I recently installed the system back on my 75 914 2.0l It had weber a carb conversion . It runs well at High way speeds but at idle and off idle it has a stumble /miss. At idle it is sometimes good but often gets rough and surges
Cold start is fine for the first 30 sec to a min then it will start stumbling and missing off idle. IT runs better when warmer and seems to idle best once coming off a hi way cruise =Robert |
mepstein |
Jan 19 2018, 09:23 AM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
www.blackforestracing.com
The owner, John Forbes, is an avid 914 enthusiast. |
rfinegan |
Jan 19 2018, 09:34 AM
mepstein |
Jan 19 2018, 10:04 AM
ranger |
Jan 19 2018, 02:17 PM
Newbie Group: Members Posts: 18 Joined: 21-November 10 From: North Carolina Member No.: 12,409 Region Association: South East States |
Check out Chuck Miller at Miller Sports 306 Rabbit ln. Hillsbough NC. 27278
(919) 644-2930...I'm sure he can help,,, |
DRPHIL914 |
Jan 19 2018, 02:21 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I need to find a shop that can work and repair a 2.0 Djet.. I recently installed the system back on my 75 914 2.0l It had weber a carb conversion . It runs well at High way speeds but at idle and off idle it has a stumble /miss. At idle it is sometimes good but often gets rough and surges Cold start is fine for the first 30 sec to a min then it will start stumbling and missing off idle. IT runs better when warmer and seems to idle best once coming off a hi way cruise =Robert vacuum leak suspected, or lean running, could be bad MPS developing too. |
thelogo |
Jan 19 2018, 03:16 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
(IMG:style_emoticons/default/av-943.gif)
Djet specialists You guys crack me up around here (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/laugh.gif) |
Dave_Darling |
Jan 19 2018, 04:26 PM
Go to this website, and read read read read READ! You will likely wind up knowing as much or more than anyone at the aforementioned shops...
http://members.rennlist.com/pbanders --DD |
Mblizzard |
Jan 19 2018, 04:35 PM
Also would suspect TPS sensor board of there are no vacuum leaks and the MPS is good.
era vulgaris |
Jan 19 2018, 04:43 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
If you can make the 3 hour drive, I'd take it to Black Forest Racing. I've been down there with both of my 914's and they know these cars probably better than any other shop in NC.
There's also Road Scholars in Durham, but they are $$$$$. I've never been been there so I can't say how well they know their stuff. They quoted me $1600 to replace an RMS on my old '75, so I said thanks but no thanks! |
Lo-Fi Version | Time is now: 9th June 2024 - 09:36 PM |
