Bulb type list?, Anyone have one made |
Kerrys914 |
Jul 9 2003, 08:58 AM
Dear, the parts I just sold paid for that part ;) Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 |
I need to buy new bulbs all around for my '74. Does anyone have a list of bulb types and the qty of each handy?
Cheers Kerry getting close (IMG:style_emoticons/default/driving.gif) |
JeffBowlsby |
Jul 9 2003, 09:27 AM
914 Wiring Harnesses Group: Members Posts: 8,513 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I have started one awhile back...its not complete or guranteed accurate...use at your own risk. Lessee if it pastes in with proper tab delimits:
1974 Porsche 914 Lamp Index Number Volts Watts Filament Lamp H-4 55/60 dual Euro Headlamp (halogen) 6014 60/50 dual USA Headlamp (sealed tungsten) H-3 55 single Euro foglamp 35 single USA foglamp 1157 12 21/5 dual USA Front turn signal/parking (front turn signal housing) 1895 12 4 single USA Front side marker High beam indicator (bottom of tachometer) Turn signal indicator (top of tachometer) Parking lamps indicator (bottom of speedometer) Tachometer illumination (2) Speedometer illumination (2) 12 1.2 single Seatbelt indicator 12 1.2 single Heater control assembly illumination (3) 12 1.2 single Fresh air blower indicator Alternator charge indicator (combo gauge) Low fuel warning (combo gauge) Oil pressure indicator (combo gauge) Parking brake warning indicator (combo gauge) Fuel gauge illumination (combo gauge) Clock illumination (center console) Oil temperature illumination (center console) Voltmeter illumination (center console) 12 1.2 single Defroster lever illumination (center console) 12 1.2 single Fog lamp indicator (under dash switch bezel) 12 1.2 single Hazard flasher indicator (under dash switch bezel) 12 10 single Interior cabin (backpad) 12 4 single Rear luggage/engine bay (or is it 10W?) 1157 12 21/5 dual Stop/rear (taillight housing-parking taillight-brake)(1034?) 7506 12 21 single Rear turn signal (taillight housing) (1073?) 1816 12 5 single USA rear side marker (taillight housing) 15607 12 10 single Rear license plate (2) 12 21 single Rear back-up (Phillips-12498, 15894 – 1816 or 1891?) |
JeffBowlsby |
Jul 9 2003, 09:28 AM
Nope...not gonna do it...send me your email address and I will email it to you as an attachment.
Kerrys914 |
Jul 9 2003, 01:25 PM
Just to clarify..
I am replacing the; - interior light - All the lights in the rear tail light assembly - The bulbs in the front - Light in th eengine bay - Light in the trunk Also I have euro lense if it makes a diff in the rear lights (IMG:style_emoticons/default/smile.gif) Cheers Kerry |
Demick |
Jul 9 2003, 01:47 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
From an old Automotion catalog. You should be able to cross reference the part numbers to whatever brand your FLAPS carries.
Automotion used to sell a bulb kit with all of the bulbs needed for the car - 16 bulbs total for $15. Not sure if Performance Products now sells the same thing. Parking Light: LB-7382 Front Turn Signal: LB-7382 Front Side Marker: LB-7172 Tail Light: LB-7382 Stop Light: LB-7382 Rear Turn Signal: LB-7322 Rear Side Marker: LB-7172 License Plate 70-74: LB-7172 License Plate 75-76: LB-7182 Back Up Light: LB-7102 Interior: LB-7232 Instrument/Indicator: LB-7222 Luggage: LB-7172 Pull Switches, Heater Control, Seat Belt: LB-7228 Demick '74 2.0 |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:40 AM |
