Fuchs backspacing, Will the 15 x 7 & 8” off a 944 have the correct backspacing for a GT clone ? |
jeff |
Jan 24 2018, 03:12 PM
Member Group: Members Posts: 252 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
Spotted some 15 x 7 & 8” , wondering if they willlook correct on a GT clone, I’d rather not use big spacers..
mepstein |
Jan 24 2018, 03:49 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Perfect size for a GT car. Some people do use a 1" spacer behind the front wheel.
theer |
Jan 24 2018, 04:01 PM
Senior Member Group: Members Posts: 677 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I have the exact same idea.. but don't have the car and wheels in the same place to try it out...
Here's some data: The 944 Fuchs 15x7 have an offset (ET) of 23.3mm; the 15x8 are ET 10.6mm. Compare that to the 15x5.5 4-lug Fuchs' ET of 42mm. So, it seems the backspacing is almost identical on all three Fuchs sets at ~4.9in, which means you won't need a spacer to avoid hitting any suspension bits with the INSIDE of the rim/tire.. which is good. That also means the extra wheel width will all be to the outside: the fronts will stick out 1.5" and the rears 2.5" further on each side than the 4-lug Fuchs. Depending on how big you go with your GT flares, you may end up wanting spacers if the wheels don't fill up the space. |
gothspeed |
Jan 24 2018, 04:07 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
I have started a thread on fuchs widths. It seems 7 and 8 x 15 are popular in the looks department (IMG:style_emoticons/default/smile.gif)
thread: http://www.914world.com/bbs2/index.php?showtopic=322764 Here are pics of 7 and 8 x 15 on a GT tribute (clone). I prefer the name tribute though (IMG:style_emoticons/default/wink.gif) There are many other awesome pics in the thread link above as well (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) Attached image(s) |
mepstein |
Jan 24 2018, 04:16 PM
To me, the 7&8x15 are perfect for looks, ride height, steering effort and price. Everyone will have a preference but at least this size is tried and true. It will fit any GT flared car without issues.
jeff |
Jan 24 2018, 04:19 PM
I was worried about the backspacing, are the 944 ones much different than the 911 15 x7 & 8 ?
Justinp71 |
Jan 24 2018, 04:21 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Perfect size for a GT car. Some people do use a 1" spacer behind the front wheel. If you flare the front you have to space out the wheel 1 to 1.5". Otherwise it doesnt look right. 7" front wheels will fit on a stock bodied car. I personally have 100mm studs and run 1.5" of spacers. With the longer studs you dont have to worry about the spacers coming loose. Works Great! |
Justinp71 |
Jan 24 2018, 04:31 PM
I was worried about the backspacing, are the 944 ones much different than the 911 15 x7 & 8 ? I got a set from a 944 and one from a 911 and they are identical. Now I don't know if they were factory original. Maybe someone that knows more will chime it. But all 15x7's and 15x8's I've ever seen were the same offset. |
theer |
Jan 24 2018, 04:35 PM
I was worried about the backspacing, are the 944 ones much different than the 911 15 x7 & 8 ? The early 15" Fuchs are all 911 part numbers and should be the same - assuming they are "real" Fuchs. The later 16" Fuchs have different 911 vs 951 (aka 944 turbo) part numbers. Some good info from Pelican: http://forums.pelicanparts.com/porsche-911...-944-fuchs.html |
mepstein |
Jan 24 2018, 04:53 PM
I was worried about the backspacing, are the 944 ones much different than the 911 15 x7 & 8 ? I got a set from a 944 and one from a 911 and they are identical. Now I don't know if they were factory original. Maybe someone that knows more will chime it. But all 15x7's and 15x8's I've ever seen were the same offset. 8" - 951 Fuchs (from a 944) have a different offset. They look like 7's from the front and sit closer to suspension than a 911- 8" fuchs. That's why the narrow body 911 guys like them on the front. You would pay a premium and not really need them. They go for around $1200-1500/pair. |
burton73 |
Jan 24 2018, 05:12 PM
burton73 Group: Members Posts: 3,539 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I just happen to have a picture of my 951s in 7 and 8 x 16
Bob B |
gothspeed |
Jan 24 2018, 05:16 PM
I had a set of 951 7s and 8s .... but I sold the 7s ..... I should have kept the 7's and sent them to get widened ..
burton73 |
Jan 24 2018, 06:01 PM
ConeDodger |
Jan 24 2018, 06:05 PM
Apex killer! Group: Members Posts: 23,606 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The 944 guy’s are convinced the Fuchs in 944 offset are made of gold. A set such as you are describing? $2500 range! (IMG:style_emoticons/default/sad.gif)
jmitro |
Jan 24 2018, 09:02 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
The 944 guy’s are convinced the Fuchs in 944 offset are made of gold. A set such as you are describing? $2500 range! (IMG:style_emoticons/default/sad.gif) 15s or 16s? To me, the 7&8x15 are perfect for looks, ride height, steering effort and price. Everyone will have a preference but at least this size is tried and true. It will fit any GT flared car without issues. agree, they are perfect for everything except tire options (IMG:style_emoticons/default/sad.gif) |
horizontally-opposed |
Jan 24 2018, 10:19 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
To me, the 7&8x15 are perfect for looks, ride height, steering effort and price. Everyone will have a preference but at least this size is tried and true. It will fit any GT flared car without issues. agree, they are perfect for everything except tire options (IMG:style_emoticons/default/sad.gif) Actually, we are in luck there. There are several options to put good tires on them for a GT in the correct 195/65 or 185/70 front and 215/60 rear, all of which perform well and look period correct: Avon CR6ZZ Pirelli P6000 N2 (Porsche approved) Pirelli CN36 I'd do the P6000s on the street (I am running the Avons and don't love them), which is what you see on the yellow car above. Are they as good as modern autocross or track tire? No. But those can be had, too. 225/50R15 allows one to go square on seriously sticky rubber, and then there are dedicated race tires. And if you want vintage looks with SERIOUS performance, you can always go the Michelin TB15 route... |
gothspeed |
Jan 24 2018, 10:57 PM
I had a set of 951 7s and 8s .... but I sold the 7s ..... I should have kept the 7's and sent them to get widened .. The 951 7s are the same as the 911. 7s 16 That is in my picture. I have 911 7s 951 7s and 8s Bob B 951 7s have a different offset than 911 7s. Look at recessed lug seats of 951 7s compared to 911 7s lug sockets. |
HaraldD |
Jan 25 2018, 12:43 AM
Member Group: Members Posts: 90 Joined: 23-November 08 From: Germany Member No.: 9,781 Region Association: Germany |
Hello to everyone,
here you see 7 + 8 (in 16") from 944 Turbo at my Car... (IMG:style_emoticons/default/driving.gif) Harald |
zig-n-zag |
Jan 25 2018, 01:24 AM
Member Group: Members Posts: 182 Joined: 18-May 06 From: Hawaii Member No.: 6,024 |
Specific to 944's, 7x15, part #911 361 020 41, or part #911 361 020 93. Black star
or unvarnished, both rim flange polished. Specific to 944's, 8x15, part #911 361 020 42, or part #911 361 020 94. Black star or Unvarnished, both rim flange polished. |
gothspeed |
Jan 25 2018, 09:09 AM
Hello to everyone, here you see 7 + 8 (in 16") from 944 Turbo at my Car... (IMG:style_emoticons/default/driving.gif) Harald Looks awesome (IMG:style_emoticons/default/smilie_pokal.gif) !! Any spacers, rolled fender edges or clearance issues? Oh and that front spoiler/valance!! Is that still available? Fiberglass? |
Lo-Fi Version | Time is now: 2nd June 2024 - 06:47 AM |
