What size bolt for door hinges? |
raynekat |
Jan 25 2018, 09:51 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
What are the size bolt M?x? for the door hinges on these cars?
Are the M8x16 cheeseheads? Guess I'd need 12, 6 per side or 3 per hinge. There's a flat and lock washer that goes with each? Thanks in advance.... |
914werke |
Jan 25 2018, 10:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Actually they are a special pointed or tapered bolt used only on the hinges of the doors
I think they are M8 x 1.25 x 35 or the like. And yes Washers & split lock washers. |
cary |
Jan 25 2018, 10:45 PM
Top secret. There should 2 in each hinge when you pull the door braces. (IMG:style_emoticons/default/biggrin.gif) |
bbrock |
Jan 25 2018, 10:48 PM
I happened to have one in front of me when I opened this, so snapped a quick pic. Threaded length is 22mm and 28mm from shoulder to tip of point.
Attached image(s) |
raynekat |
Jan 25 2018, 11:50 PM
So is that the bolt that holds the hinge onto the door?
or holds the hinge onto the body? I'm after the latter one....what bolts the hinges/doors to the body. |
cary |
Jan 26 2018, 12:05 AM
cary |
Jan 27 2018, 09:57 AM
Here's what's not in the project door braces. In case you cant find yours.
Lo-Fi Version | Time is now: 2nd June 2024 - 07:59 AM |
