cooling flaps, how do they work? |
joeav8tor |
May 31 2005, 06:54 PM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
hello,
I retinned my engine and am getting ready to reinstall it...I wanted to make sure that my cooling flaps are operating properly before I do this...right now the cable that comes off of the thermostat is tight and the flap on the same side of the thermostat is closed as far as it will go (1/2 inch from being completely closed, it wont close any further). the flap over the oil cooler is opposite, it is completely open....is this correct, and what purpose are the flaps for...the haynes manual eludes to the fact that the flaps should be in the same position....thanks for the help! Joe |
9144guy |
May 31 2005, 07:00 PM
Member Group: Members Posts: 253 Joined: 26-February 05 From: tulsa,ok Member No.: 3,672 |
take them out unless it gets to 35 deg. weather, unless its for show.
Allan |
May 31 2005, 07:03 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
joeav8tor |
May 31 2005, 07:25 PM
thanks for posting that thread to cooling flaps...it looks like it is working properly ...found this post by brad roberts
The drivers side flap when closed opens the passenger side flap. This cuts off air to the drivers side cylinders (to warm them up) and lets the air on the passenger side go OVER the oil cooler instead of through it. The passenger side also tries to block some of the air for those cylinders (warming that side up also) thanks for the replies! Joe (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
dmenche914 |
May 31 2005, 07:35 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
No, No, No. leave the flaps installed, and functional. Even if the controlling bellows fails, the flaps will go to the spring loaded fail safe position. If you remove the flaps, the air will not be directed correctly, they need to be installed for the best, most even cooling.
Cooling Flaps is good too have, cause a functional system allows the car to warm up faster, which reduces wear, and smog. |
Lo-Fi Version | Time is now: 28th May 2024 - 05:02 PM |
