Mowog4 |
Member ![]() ![]() Group: Members Posts: 291 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None ![]() ![]() |
I am using one of the available brackets with a Honda MC on a Subi conversion. Is the spring on the clutch pedal still used? Seems like it would b eliminated.
Thanks |
Mowog4 |
Any thoughts?
billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States ![]() |
Aren't pedal return springs used on all pedals...mechanical linkage or hydraulic?
I know the Porsche 996 (with hydraulic clutch) uses a spring. I think pretty much every car does. Then again, I don't claim to be an expert. |
dwillouby |
Member ![]() ![]() Group: Members Posts: 393 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None ![]() ![]() |
Aren't pedal return springs used on all pedals...mechanical linkage or hydraulic? I know the Porsche 996 (with hydraulic clutch) uses a spring. I think pretty much every car does. Then again, I don't claim to be an expert. If I recall the return spring is required to assist the master cylinder to restore pedal position. May have to take a look. David |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
You need to fab a return spring, which is opposite the way the stock spring works. So yes, cut out the stock spring.
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
On my hydraulic clutch setup, I replaced the existing spiral wound spring with one that is wound in the opposite direction so as to function as a return spring. I used a McMaster-Carr spiral spring, and modified the ends to re-create the hooks. I used a small butane torch to anneal the ends in order to make them easier to form. I don't have the McMaster-Carr part number at the office; will have to wait till I get home and dig it up.
Andys |
Mowog4 |
On my hydraulic clutch setup, I replaced the existing spiral wound spring with one that is wound in the opposite direction so as to function as a return spring. I used a McMaster-Carr spiral spring, and modified the ends to re-create the hooks. I used a small butane torch to anneal the ends in order to make them easier to form. I don't have the McMaster-Carr part number at the office; will have to wait till I get home and dig it up. Andys Thanks, I really appreciate you finding the part number. Ed |
Mowog4 |
I do love this forum, thanks for the help
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,555 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
So I am using Tilton pedals for my brake and clutch. I had not thought of putting in any springs till I saw this. 2 masters for the brakes and one for the clutch.
What have my brothers that are running a race set up like this done? What to do for a brake light switch? Thanks as always for all the info. It make it so much easer that in the old days. Bob B |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,614 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Aren't pedal return springs used on all pedals...mechanical linkage or hydraulic? I know the Porsche 996 (with hydraulic clutch) uses a spring. I think pretty much every car does. Then again, I don't claim to be an expert. My son’s 944 has a return spring. I know this because I just paid for a new one. (IMG:style_emoticons/default/blink.gif) Oh, and yes it has a hydraulic clutch. |
dwillouby |
I left the stock spring in place.
Works perfect. David |
Mowog4 |
dwillouby |
What the spring does is take the slack out of the system. Puts a preload on the cable / master cyl. Does not exert enough pressure against a properly bled Wilwood m/c to cause an issue.
That's my opinion, have been wrong before. ( but I have stayed in a Holiday Inn many times (IMG:style_emoticons/default/smile.gif) ) David |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
What the spring does is take the slack out of the system. Puts a preload on the cable / master cyl. Does not exert enough pressure against a properly bled Wilwood m/c to cause an issue. That's my opinion, have been wrong before. ( but I have stayed in a Holiday Inn many times (IMG:style_emoticons/default/smile.gif) ) David (IMG:style_emoticons/default/agree.gif) 3 yr's & 11,000 miles later. (IMG:style_emoticons/default/beerchug.gif) |
Mowog4 |
What the spring does is take the slack out of the system. Puts a preload on the cable / master cyl. Does not exert enough pressure against a properly bled Wilwood m/c to cause an issue. That's my opinion, have been wrong before. ( but I have stayed in a Holiday Inn many times (IMG:style_emoticons/default/smile.gif) ) David (IMG:style_emoticons/default/agree.gif) 3 yr's & 11,000 miles later. (IMG:style_emoticons/default/beerchug.gif) Who am I to argue with the wisdom of the Holiday Inn, it will go in with the stock spring. Thanks for the help. Ed |
Lo-Fi Version | Time is now: 10th June 2024 - 01:25 PM |
