> Gauge restore and LED upgrade, step by step video
iankarr
post Jan 31 2018, 10:15 AM
Hi Guys,
Just finished restoring my gauge cluster and installing the LED upgrade described by Timothy_nd28. Here's the vid...
https://www.youtube.com/watch?v=r3xJxEiIlIQ
And here's Tim's step by step post...
http://www.914world.com/bbs2/index.php?sho...=212130&hl=
Replies(1 - 19)
Coondog
post Jan 31 2018, 10:42 AM
Thank you for posting, this mod is on my bucket list for sure.
pete000
post Jan 31 2018, 11:59 AM
Does the dimmer still work?
mtndawg
post Jan 31 2018, 12:44 PM
Easy to follow, clear audio, nice close up shots, really well done video!
iankarr
post Jan 31 2018, 12:51 PM
QUOTE(pete000 @ Jan 31 2018, 12:59 PM) *
Thanks guys.
the dimmer worked on my '73 with this upgrade. haven't installed this new cluster in my 74 yet, but no reason to think it wouldn't work as well.
porschetub
post Jan 31 2018, 03:12 PM
QUOTE(cuddyk @ Feb 1 2018, 07:51 AM) *
Thanks guys.
Done this myself and yes it is very effective,I purchased 3 x 300mm LED strips already to go in,on the tach I found that was a little short but didn't have any effect as there was plenty of light.
My dimmer is bypassed as with my headlight switches both had dimmers fail one after the other (IMG:style_emoticons/default/headbang.gif) .
Great video (IMG:style_emoticons/default/beerchug.gif) .
timothy_nd28
post Jan 31 2018, 03:13 PM
Very nicely done and one handed nonetheless! (IMG:style_emoticons/default/beerchug.gif)
I nominate this procedural video for the classic section! Pictures don't do these upgrades any justice, however your video of the gauges being lit up did the trick.
Since doing these conversions for other members, I did learn something not good since my original writeup, a electrical short. The flexible LED strip has a sticky adhesive on the back end. For whatever reason, when sticking the LED's inside the gauge can, the bottom of the flexible PCB shorted to the metal. Not taking any chances on future conversions, I have been applying a layer of double sided sticky foamy tape to the interior of the gauge can, then appling the LED strip ontop of this tape. The tape acts as a good electrical insulator and it also doubles as something to grab ahold of any loose light bulbs that happen to fall out of its lamp holder (IMG:style_emoticons/default/biggrin.gif)
iankarr
post Jan 31 2018, 07:51 PM
Thanks for the heads up Tim!
Chris914n6
post Jan 31 2018, 08:05 PM
Jackstands are my life.
Happen to measure the thickness of the glass?
I've got a guy that will cut glass cheap but my later gauge, with the plastic lens, is about half as thick. Same thing with my 944 combo gauge, only 1/16" or so thick.
bbrock
post Jan 31 2018, 08:24 PM
Nice video! FYI, you can solder leads to any of the copper pads on the cut lines of the LED tape. it doesn't have to be just at the soldered ones. (IMG:style_emoticons/default/beerchug.gif)
ConeDodger
Apex killer!
Nice!
iankarr
post Jan 31 2018, 08:36 PM
QUOTE(Chris914n6 @ Jan 31 2018, 09:05 PM) *
Here ya go... this is original glass. 2.92mm / .115 inches (or 7/64). I replaced the ones on my gauges and just told the glazier to match the thickness. keep in mind that if you powder coat the rings you may need a slightly thinner glass. These lenses are installed under surprisingly tight tolerances and if the glass/ring combo is too thick, there won’t be enough metal left to re-crimp.Attached Image
Chris914n6
post Jan 31 2018, 09:02 PM
I found Model Masters 28913 Red Orange to be a near perfect match for needles. Should be found at your local hobby store with models.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-431-1517454158.1.jpg)
gothspeed
post Feb 1 2018, 10:56 AM
Dimmable LEDs makes this awesome! (IMG:style_emoticons/default/smile.gif)
Kansas 914
post Feb 1 2018, 11:16 AM
QUOTE(Chris914n6 @ Jan 31 2018, 08:02 PM) *
stickyfingers
post Aug 18 2022, 05:57 PM
Hi Ian. Video is amazing. Can someone recommend the LED strips from Amazon that will work?
Thanks.
Retroracer
post Aug 18 2022, 06:23 PM
QUOTE(Chris914n6 @ Jan 31 2018, 07:05 PM) *
I see the OP posted above in the thread (post #12) the measured thicknesses. Its worth noting that if you do replace the plastic lenses with glass, then either use a bezel that came with OG glass lens, OR match the thickness of the plastic with the replacement glass. If you don't, re-crimping the bezel will be a bear of a task.
Ask me how I know..... (IMG:style_emoticons/default/dry.gif)
- Tony
PS. @Iankarr Excellent video there!
JamesJ
post Aug 18 2022, 07:00 PM
Just a comment regarding the LED strips. Palo Alto Speedometer suggested I use LED bulbs because the LED strips emit different lighting for each gauge because each housing is different. YMMV
NARP74
post Aug 19 2022, 09:52 PM
Since we are revisiting the past, where does one source the bulbs for an upgrade? My son was just asking if I was going to do this mod?
Geezer914
post Aug 20 2022, 05:52 AM
Geezer914
I replaced all the bulbs with blue LED's except the generator bulb.
- Lo-Fi Version Time is now: 31st October 2026 - 11:16 AM
