mmascari |
Member ![]() ![]() Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None ![]() |
SOLD
I am selling 2- Euromeister 16x7 wheels. I purchased these to test fit but do not fit my Boxster calipers. They rub the caliper on the inside. Anyway, the tires will be removed and the wheels shipped in the original boxes. Brand new never used. Only installed tires to test fit. $300 plus buyer pays shipping. Thanks. Attached thumbnail(s) ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Good deal !
Mitox |
Member ![]() ![]() Group: Members Posts: 399 Joined: 26-October 15 From: SW Virginia Member No.: 19,302 Region Association: South East States ![]() ![]() |
I have the same wheels for the front of my 914 GT project. I haven't mounted them yet, and was thinking about using the Boxster brakes also. Were your problems with non-S calipers or S calipers?
I assume it was Non-S, but want to be sure. Thanks |
mmascari |
I have the same wheels for the front of my 914 GT project. I haven't mounted them yet, and was thinking about using the Boxster brakes also. Were your problems with non-S calipers or S calipers? I assume it was Non-S, but want to be sure. Thanks The problem was in the rear. I have a stock bodied car. I thought maybe they could squeeze in there but when I went to mount the wheel it hit the caliper on the inside. I could use a small spacer but then the tire would stick out even further not allowing the tire to fit on the outside. I have non-S Boxster calipers on all four corners. Unfortunately the only wheel that I think will fit with my calipers/stock body is the Boxster 16" wheel that I have on the car now. I guess I will have to do flares some day. |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Wow, this does seem like a great deal....
GLWTS |
Mitox |
I have the same wheels for the front of my 914 GT project. I haven't mounted them yet, and was thinking about using the Boxster brakes also. Were your problems with non-S calipers or S calipers? I assume it was Non-S, but want to be sure. Thanks The problem was in the rear. I have a stock bodied car. I thought maybe they could squeeze in there but when I went to mount the wheel it hit the caliper on the inside. I could use a small spacer but then the tire would stick out even further not allowing the tire to fit on the outside. I have non-S Boxster calipers on all four corners. Unfortunately the only wheel that I think will fit with my calipers/stock body is the Boxster 16" wheel that I have on the car now. I guess I will have to do flares some day. Thanks for the feedback. I'll need to figure out what to do for brakes soon. |
Beach914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 968 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California ![]() ![]() |
I'm interested and can a UPS acct # to ship down to Orange, Ca. What are the box sizes and weight so I can estimate the ground shipping?
thx |
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,559 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
I have the same wheels for the front of my 914 GT project. I haven't mounted them yet, and was thinking about using the Boxster brakes also. Were your problems with non-S calipers or S calipers? I assume it was Non-S, but want to be sure. Thanks The problem was in the rear. I have a stock bodied car. I thought maybe they could squeeze in there but when I went to mount the wheel it hit the caliper on the inside. I could use a small spacer but then the tire would stick out even further not allowing the tire to fit on the outside. I have non-S Boxster calipers on all four corners. Unfortunately the only wheel that I think will fit with my calipers/stock body is the Boxster 16" wheel that I have on the car now. I guess I will have to do flares some day. Thanks for the feedback. I'll need to figure out what to do for brakes soon. On the Boxster brakes Hi Robert, Any Porsche 15 or 16" alloy wheel, 7" or wider will fit over the boxster caliper. My guess is the guy bought the "cost effective" cast Fuchs copies which have a completely different ID. You're golden and the best of luck with the project! Rich Bob B |
mmascari |
Lo-Fi Version | Time is now: 17th June 2024 - 07:22 AM |
