> Whats this rectangle hole for?
simonjb
post Feb 25 2018, 01:28 PM
KiwiMan
Can someone tell me what goes in/through the rectangle you see here in the engine tin??
Replies(1 - 6)
McMark
post Feb 25 2018, 01:32 PM
914 Freak!
Intake air pre-heater plumbing passed through that spot. Only present on early cars (70-71)
914werke
post Feb 25 2018, 01:37 PM
(IMG:style_emoticons/default/agree.gif) in conjunction with the oil bath air filter
Spoke
post Feb 25 2018, 01:57 PM
Jerry
If the hole isn't blocked off it should be to stop the cooling air from escaping to the engine compartment instead of going past the cylinders.
McMark
post Feb 25 2018, 04:25 PM
914 Freak!
QUOTE(Spoke @ Feb 25 2018, 02:57 PM) *
This hole doesn't enter the cooling air section of the tin. It just passes from the bottom to the top. So, plugging it will stop hot air from travelling up from underneath, but I'd hardly be concerned with that amount of air. Leaving it open shouldn't affect anything.
r_towle
post Feb 25 2018, 05:04 PM
Custom Member
QUOTE(McMark @ Feb 25 2018, 05:25 PM) *
Considering it’s right above the exhaust system, I would close it off so you don’t suck hot air from below. The rubber seal around the engine tin is not for looks, it has an engineered purpose.
mgphoto
post Feb 26 2018, 12:19 PM
"If there is a mistake it will find me"
This preheater is also on MY '72 goes away with the paper air cleaner MY '73.
- Lo-Fi Version Time is now: 16th June 2024 - 07:54 PM
