LA Mechanic, Suggestions on a mechanic in LA? |
RMCD |
Mar 3 2018, 06:17 PM
Newbie Group: Members Posts: 1 Joined: 21-February 18 From: Santa Monica Member No.: 21,912 Region Association: Southern California |
Hi new here and to a 914. I'm in an apartment complex without a garage so I can't do too much work on the car (nor do I know how yet). Does anyone have a recommendation for a mechanic in LA?
I'm excited to learn over time but I just drove it from Seattle to LA and the final day of the drive the starter stopped working, so it has been rolling starts since. I couldn't find it in another thread, sorry if I missed it and sorry if asking for a mechanic is sacrelige. Thanks, Ryan Attached thumbnail(s) |
Tom_T |
Mar 3 2018, 06:31 PM
Nice pic Ryan! .... & a brave 1st timer drive!
I'll let the LA folks recco shops up closer to you, but PM me later if you come up dry & I can recco some OC ones. With all the rain coming down from Seattle, you may also want to check to make sure that you're not getting a short from the wetness &/or corrosion at any of the starter & battery connections. That can cause low voltage insufficient to turn the starter &/or to move the solenoid. That starter issue is common on 914s & all VWs at some points in their lives, & sign that you're ready for a new one, but you'll probably only find reman Boash units out there, or an aftermarket replacement in standard or high-torque flavors.. There is another workaround if you can't push it, but you'll need a helper in the car to turn the key to start it, while you crawl under with a ball peen hammer, heavy wrench or something to tap on the side of the body of the starter motor while they crank it. Only try this a few times, so you don't run the battery trying to start it if the starter/solenoid is completely gone. We used to affectionately call this developing a "flat spot" on the starter, but more correctly it's really either a sticky solenoid, or sticky shaft/bearings on the starter itself, or a section of the windings which aren't developing enough current to turn the motor. At some point all of us have gone thru the above starter tapping trick &/or parking on a slope for a running getaway! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/welcome.png) . PS - You're on the right forum for this topic/question, & lots of folks ask for mechanics. It's also a good idea to plan longer trips ahead with a list of shops who know 914s along your route. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
emmanueldelvalle |
Mar 3 2018, 06:39 PM
Newbie Group: Members Posts: 3 Joined: 26-April 14 From: Los Angeles Member No.: 17,286 Region Association: Southern California |
There is a little shop in Montery Park (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png) on the east side of nL.A.
Jim's Vw Service & Repair Jim has been there for over 20 years 849 E Garvey Ave Montery Parc 91755 (626) 288-9760 (IMG:style_emoticons/default/welcome.png) |
914-300Hemi |
Mar 3 2018, 09:56 PM
Senior Member Group: Members Posts: 1,356 Joined: 7-September 06 From: San Dimas, CA Member No.: 6,794 Region Association: Southern California |
Ryan
Very nice car (IMG:style_emoticons/default/welcome.png) Replacing the starter is an easy job that can be done with no special tools. What part of LA are you in? |
SO.O.C914er |
Mar 3 2018, 10:17 PM
Senior Member Group: Members Posts: 1,263 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
Congratulations on the nice find. If you get into some serious motor work or maintenance Hector at PCH garage in sunset beach is the man to see. (IMG:style_emoticons/default/welcome.png)
Lo-Fi Version | Time is now: 7th June 2024 - 10:25 PM |
