BPic |
Member ![]() ![]() Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States ![]() ![]() |
Started gutting for my rebuild and found a couple of areas needing new metal. I can fabricate if needed but if these are available somewhere I would prefer to just buy them, preferably new. In the photo the highlighted area that hold the seal for the front trunk and, also highlighted and circled in red the area that mounts the front hood release. I have a feeling this is the second hell hole on the car based on where it is welding is gonna be an issue.
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,732 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
The cowl was available as a factory part, and it may be possible to find an NO$ piece for that but doubtful. No one is making reproductions of that area at this time
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Ive made Cary the channel marerial for the front trunk. Just needed some feed back, but as bent oieces these will be inexpensive.
Bobco |
Newbie ![]() Group: Members Posts: 35 Joined: 10-May 17 From: Butler pa Member No.: 21,091 Region Association: North East States ![]() |
Mark. I could use a piece of the channel if your making it.Let me know what length it comes in.Thanks Bobco
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,157 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
HERE you go.
A little rough but good for patching, & priced reasonably. (IMG:style_emoticons/default/smile.gif) |
BPic |
Ive made Cary the channel marerial for the front trunk. Just needed some feed back, but as bent oieces these will be inexpensive. Mikey914, I am definitely interested. What kind of feed back do you need? I could use the bent piece in the photo and another 18 inches of straight to patch some other areas. |
cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels.
Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. ![]() It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. |
cary |
I stand corrected. Its on my own project car.
Starts about here. http://www.914world.com/bbs2/index.php?s=&...t&p=2300708 |
cary |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. I think that was the toughest repair I made on my car, and that was with the floor completely removed. Here's about where my saga begins: http://www.914world.com/bbs2/index.php?s=&...t&p=2563442 I could use a couple pieces of the channel too, but I'm going to try to check it off my list in within a month so won't be able to wait. (IMG:style_emoticons/default/sad.gif) |
cary |
I don't want hold anyone up. I sure Mark can ship what he has made up already.
But they are straight pieces. One would need a shrinker stretcher to create the correct shape. IMO. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,513 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels. Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. ![]() It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. Shiny! What kind of material are those channels made from? Aluma-steel, galvanized or plain clean steel? |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,903 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels. Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. ![]() It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. Shiny! What kind of material are those channels made from? Aluma-steel, galvanized or plain clean steel? Looks like cold rold to me.. |
cary |
BPic he's waiting for me to get back to working on Taylor's car and use the pieces on Taylor's trunk channels. Based on my schedule for the next 6-8 weeks I won't be back on Taylor's car till May. Here's what Mark's had created. ![]() It was created primarily for the channels around the headlight buckets. If I were you I'd snag that piece Rich has offered up. If you don't take it I probably will take. Most cars have the issue your seeing in that left upper front trunk channel corner. The way they layered it it leaves a pocket under the old foam seal. As does the piece Rich offered. The channel corner I repaired on Doug's car somewhere close to the end. http://www.914world.com/bbs2/index.php?act...=2&t=249327 The trunk pull pocket is a real tough repair. I think I did it on one of Mark's car. Can't find it at the moment. I'll keep looking. That's a real tough place to work. Shiny! What kind of material are those channels made from? Aluma-steel, galvanized or plain clean steel? Looks like cold rold to me.. That would be my guess ............................... it's steel |
Lo-Fi Version | Time is now: 16th June 2024 - 07:19 PM |
