Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,330 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
I put a lot of time setting up the heating system, only to find out that I should block off the right heat exchanger. I hate to do that so I am in need of a splitter for the hose used on 75-76 models. Any one have one?
Garland |
The blower
Attached image(s) ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
call the usual parts houses, EASY, HPH, Parts Heaven etc ...
also, you could "upgrade" to the VW-bus blower that has 2 outlets .... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Garland |
Sir Andy, I have a 2 outlet blower from a 914, just would like to use the mount in the car. Found AA has it but $$. Looking for one someone may have laying around.
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Pelican has the tubes, and the splitters.
M |
SirAndy |
that's why i suggested the places above. they will have the part used and much cheaper than AA ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Garland |
I will try Pelican in the morning. There listing has the tubes only, yet the picture shows the spliter.
Garland |
Worked with 3 Pelican part guys over 4 days and, they show the part on the web page.....but don't stock it. They will look around and get back with me if any luck in finding one. If a member has one of these let me know if you would be willing to part with it. Attached image(s) ![]() |
SirAndy |
ok, i try that *one* more time, three is a charm ... EASY, HPH, Parts Heaven here, i even give you the phone#s ... EASY, http://www.easypor.com/, (510) 653-3279 HPH, http://www.highperformancehouse.com/, (650) 364-6234 Parts Heaven, http://www.partsheaven.com/, (510) 782-0354 some people just don't want to listen ... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) Andy |
Garland |
I here you and I will call them all this time, and let you know.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
PP sells new parts and EASY, HPH, Parthaven sell used parts which I haven't heard of the splitter being available new. |
kenpolives |
Member ![]() ![]() Group: Members Posts: 167 Joined: 31-December 03 From: Albany NY Member No.: 1,479 ![]() |
I'll be putting my heating system in soon, I have the spliter to go on the fan, here is my question, if you route the fan output hoses to both sides of the engine sheet metal (through the tubes), where do you get the fresh air for the fan input? if any?
ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
It draws the fresh air from within the engine compartment. Yet another reason for keeping your engine clean from extra oil and the engine compartment seals in good condition. Don't forget that even when the electric fan isn't running, the engine fan also provides air for heat - and it draws the intake air from the same source. |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) Yep, Ernie is correct.
I wish there was some way to make the booster fan hoses look decent in the engine compartment. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 07:12 AM |
