WTB: Shaft Radio Faceplate, Going to recover it |
914Sixer |
Mar 28 2018, 03:14 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Need one of these. Not cut up ones please. Somebody enlarged the holes on this one.
Attached image(s) |
Mike Fitton |
Mar 28 2018, 03:41 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
No those holes are correct for an early cars with the chrome trim that installs from the front. What Radio are you installing?
914Sixer |
Mar 28 2018, 04:17 PM
Chrome nose Becker radio with standard shaft.
914Sixer |
Apr 2 2018, 09:18 PM
Still looking
rgalla9146 |
Apr 3 2018, 06:05 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
914Sixer |
Apr 3 2018, 06:45 AM
Rory,
I just need ones with the regular holes. This plate is the only example I had. I need the ones with rounded corners where the radio nose goes thry. Reproductions are incorrect, they have square corners and are too large. |
rgalla9146 |
Apr 3 2018, 01:31 PM
Rory, I just need ones with the regular holes. This plate is the only example I had. I need the ones with rounded corners where the radio nose goes thry. Reproductions are incorrect, they have square corners and are too large. Mark Here's what I can offer. I've concentrated on Blaupunkt Frankfurts ...not Beckers The upper one is aftermarket and heavier. The lower is real ....but the face hole has square corners.....can it work for you ? |
914Sixer |
Apr 3 2018, 04:48 PM
Not seeing the pictures.
914Sixer |
Apr 12 2018, 06:42 PM
(IMG:style_emoticons/default/cheer.gif) Still needing one good one. If I can get a good one maybe we can get it reproduced the correct thickness and rounded corners.
Mike Fitton |
Apr 12 2018, 09:50 PM
GaroldShaffer |
Apr 12 2018, 10:29 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
let me check my stash of parts in the morning.
914Sixer |
Apr 13 2018, 06:34 AM
Thanks Garold.
914Sixer |
Apr 23 2018, 08:12 AM
PCA7GGR |
Apr 23 2018, 10:53 AM
Member Group: Members Posts: 251 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
Let me know if this ones works for you. The desired cutout is outlined on the back. Thanks
Sergio |
914Sixer |
Apr 23 2018, 07:07 PM
I will keep this one in mind. Hoping to find punched one with small holes.
McMark |
Apr 24 2018, 02:03 PM
I have these reproductions I made. $15 PayPal Have 8 in stock. They're zinc plated too.
Attached thumbnail(s) |
Mikey914 |
Apr 25 2018, 12:42 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I know we did a run of them too, I'll have to check with Scott to make sure, but we can do the correct early vinyl and provide with self adhesive backing. We did jump down a gage on the metal so slightly thicker, and very sturdy.
Mikey914 |
Apr 25 2018, 11:29 AM
I know we did a run of them too, I'll have to check with Scott to make sure, but we can do the correct early vinyl and provide with self adhesive backing. We did jump down a gage on the metal so slightly thicker, and very sturdy. We have these and can add the correct vinyl and adhesive tape to the back for $25.00. That includes shipping. If this works I just need your email address to send you a PayPal invoice, and your shipping address. |
GaroldShaffer |
May 1 2018, 01:12 PM
let me check my stash of parts in the morning. Final found it. If you haven't found one yet PM me. $30 includes shipping to you. Attached thumbnail(s) |
914Sixer |
May 1 2018, 04:59 PM
Yes that is the correct one.
Lo-Fi Version | Time is now: 10th June 2024 - 03:05 PM |
