tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
yes, you should use some (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
i give up, what's "j 1703" ?
the DOT rating should be on the sealed container. if it's not, it should be treated with extreme suspicion... |
Cap'n Krusty |
I use DOT 4 here at the shop. Ate "gold" or somesuch thing. Wagner, Castrol LMA should be fine. Dot 3 should be OK, as that's what was available when the cars were new. Ate "Super Blue" is good, too, but it costs more. The Cap'n
ArtechnikA |
went to the spec book for guidance, and there i discovered that the recommended brake fluid is: "SAE Specification j1703a" okay - so that's what *that* is. i donno what that "means" tho because i don't have that specification. interestingly, neither, evidently, does SAE anymore, per a search here:
SAE search for j1703 but reading between the lines a bit, my educated guess is that 1703 is DOT3, 1704 is DOT4, (which standard *is* available) and 1705 is DOT5 (similarly available). i use DOT 4 anyway. in the good ol' days i liked Castrol/Lockheed "LMA-GT" but i haven't seen it for a while - probably the packaging has changed and i just don't recognise it. i now use Valvoline SynPower DOT4. the other fluids mentioned (especially the Ate's) are quite good. no matter how good they are, change 'em every couple of years TOPS for a car in street service, before every event for a track car. |
Lo-Fi Version | Time is now: 11th July 2025 - 05:32 AM |
