somebody help me...i'm so close!, engine drop Qs.... |
bd1308 |
Jun 6 2005, 08:10 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
i have two questions:
1) How do I remove the CV joint......The bolts are gone but its still attached....whats the procedure here? 2)The engine is caught on the shift rod......it's removed from the back of the tranny but I don't know how to get the rod out of the way........ 3) My clutch cable pulley is wearing down......anybody have a GOOD one? |
Allan |
Jun 6 2005, 08:12 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I seperated my CV's with a flat screwdriver. You have to twist the shift rod around and it will slide out. Don't have a clutch pulley.
SirAndy |
Jun 6 2005, 08:13 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i count 3! 1) BFH (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) tap on it while you rotate the CV and it'll come lose ... 2) you need to disconnect it in the front, near the firewall. there's a allenhead set-screw in the coupler that holds the shiftrod. unscrew & slide out ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
URY914 |
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
1. There is a pin that mates up with holes in the flange on the tranny. Take a flat blade screwdriver and carefully pry the C/V off the flange.
Joe Bob |
Jun 6 2005, 08:14 PM
Turn and whack, turn and whack....think of Miles rotating on a spit over a barbeque.....
Aaron Cox |
Jun 6 2005, 08:15 PM
CV's - flat screwdriver - use new gaskets on reassembly.
shift rod. 1 CONE screws at the front where it goes into the body. allen head, get to it! |
Elliot_Cannon |
Jun 6 2005, 08:16 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
1. I have used a putty knife to wedge between the cvjoint to seperate it from the tranny. You'll need new gaskets.
2. I remove the engine and tranny both at the same time as one unit. The shift rod should come off before you try to get the engine/tranny out. (you should get a Haynes manual or doundload the engine removal procedure from PP. 3. Sorry, I don't have a spare cable but they are available from all the usual sources. (Don't go to a FLAPS for it). Cheers, Elliot |
Elliot_Cannon |
Jun 6 2005, 08:19 PM
I like "*" 's procedure even better. Hey "*" the No Bad Days graffic looks great on my rear window. Thanks. Cheers, Elliot |
SLITS |
Jun 6 2005, 08:32 PM
Cone screws are 4mm hex......Harbor Freight tools, set is cheap.
joeav8tor |
Jun 6 2005, 08:37 PM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
I used a big rubber mallet on the cv joints, tap and turn, a 4mm allen key will remove the cone head screw on the shifter rod near the firewall. When you get new cv joint gaskets store them away from your other parts, they are brittle and will crumble (know from experience, unfortunately)
Joe |
street legal go-kart |
Jun 6 2005, 08:39 PM
Miss Mari's slave Group: Members Posts: 437 Joined: 28-March 03 From: sierra nevada ,cali . Member No.: 490 |
Way to go Kid!
The pully is available from any Wire and Rope dist. Standard size.If you can't find a wire rope place , sailboat parts will work. Also steering pullys from an outboard moter steering system will work. Do I detect a marine theme here? Keep pounding em. JT |
Joe Bob |
Jun 6 2005, 09:13 PM
Post a pic.... |
Elliot_Cannon |
Jun 6 2005, 09:35 PM
That would take computer skills I haven't learned yet. Cheers, Elliot |
Joe Bob |
Jun 6 2005, 09:36 PM
Great....he can fly a 747 but he can't post a pic....be afraid.... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
bd1308 |
Jun 6 2005, 09:42 PM
shopping list (need ASAP):
*CV gasket *13,17,18mm wrenches |
Joe Bob |
Jun 6 2005, 09:44 PM
whatya need an 18mm for???? (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) 19mm is the one you REALLY need as well as a 15mm |
bd1308 |
Jun 6 2005, 10:23 PM
18 is for one of the engine mount....or was it the tranny mount....one of them needed 18...i think its the crossmember bolt.
SirAndy |
Jun 6 2005, 10:28 PM
* 2 (two) open end 11mm wrenches for the clutch cable nuts ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Trekkor |
Jun 6 2005, 10:35 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
ratcheting wrenches are great...
You have the ten point allen CV bolt socket, right? 8mm, I think. KT |
joeav8tor |
Jun 7 2005, 05:41 AM
17mm and 19mm for the engine and tranny bolts.
Joe |
Lo-Fi Version | Time is now: 10th June 2024 - 04:03 AM |
