Clutch, Roll pin |
Clutch, Roll pin |
shane |
Apr 12 2018, 07:11 AM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
Hi, am rebuilding my pedal assembly and read a post saying if you use a roll pin it will fail pretty fast. What's everyone using? And what size? Thanks in advance
GeorgeRud |
Apr 12 2018, 08:22 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I’d just use the original sized roll pin. If the size isn’t shown on the PET, I’d just order it through the dealer or Pelican Parts. If the rest of the pedal assembly is properly assembled (and lubricated?), there isn’t an issue with the roll pins failing prematurely.
bbrock |
Apr 12 2018, 08:50 AM
I could be wrong but I think what has been said is that you want to use a spiral style roll pin like the original and not the split hollow tube style you would typically find at the local hardware store.
Bartlett 914 |
Apr 12 2018, 09:34 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I could be wrong but I think what has been said is that you want to use a spiral style roll pin like the original and now the split hollow tube style you would typically find at the local hardware store. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 09:28 PM |
