| Bob Wolcott |
Jun 6 2005, 11:40 PM
Member ![]() ![]() Group: Members Posts: 85 Joined: 18-May 05 From: McMinnville, OR Member No.: 4,096 |
I had a look at my throttle bodies this evening (early mech injection) and there is some corrosion starting to creep in. It is still only on the surface and I want to stop it dead in its tracks. What is the best way to do this?
Thanks, Bob |
| redshift |
Jun 6 2005, 11:51 PM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
There isn't much you can so about the scaling, except for polish, and the scaling comes back.
M |
| ArtechnikA |
Jun 7 2005, 05:21 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
i can only speculate, but as i have the same setup it is not idle speculation. "best" - probably remove, strip, mask, and bead blast the factory coating, then apply a thermoset coating like one of the GunKote products. KG Coatings |
Lo-Fi Version | Time is now: 4th July 2026 - 12:29 PM |
