Full Version: How to stop corrosion in Magnesium??
Bob Wolcott
I had a look at my throttle bodies this evening (early mech injection) and there is some corrosion starting to creep in. It is still only on the surface and I want to stop it dead in its tracks. What is the best way to do this?
Thanks,
Bob
redshift
There isn't much you can so about the scaling, except for polish, and the scaling comes back.
M
ArtechnikA
QUOTE (Bob Wolcott @ Jun 7 2005, 01:40 AM)
i can only speculate, but as i have the same setup it is not idle speculation.
"best" - probably remove, strip, mask, and bead blast the factory coating, then apply a thermoset coating like one of the GunKote products.
KG Coatings
