Gauge Wiring Help, Check my wiring please |
Ed_Turbo |
Apr 21 2018, 04:07 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
Hey peeps,
I have some quick time to kill so I am on the internet. Worked on the Porsche last weekend and I wanted some wiring pros to check my work out because the damm speedo is not reading and the gauge lights at night aren’t turning on either. Something wierd is going on and I cannot find it. Also, fuse #1 is not getting a signal, but that is another story I guess Check it out. This was like my third time checking the wiring and I cannot find the problem. -Big Ed |
Ed_Turbo |
Apr 23 2018, 07:33 PM
(IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif)
Maybe it is something else? |
bandjoey |
Apr 23 2018, 07:58 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
If the speeedo is not working, then the cable is just not seated into the gauge or at the other end the transmission. unscrew the cable housing, slightly twist the housing and re-seat it.
From Pelican, here's a wiring diagram. if correct, check the fuse and clean the grounds. Attached image(s) |
Rob-O |
Apr 23 2018, 08:56 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
And as far as the gauge lighting, you may have it turned down on the light switch. I know mine likes to act wonky every once in a while. I think the rheostat inside just gets to the point where it’s not making good contact.
Ed_Turbo |
Apr 24 2018, 06:54 PM
Yeah I got that wiring template. That is how I labeled the back.
Thanks for the tips guys. I will check it out this weekend. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/beerchug.gif) -Ed |
Lo-Fi Version | Time is now: 20th May 2024 - 04:17 PM |
