914-4 Pressure plate bolt size |
AnthonyM |
Apr 26 2018, 08:29 PM
Newbie Group: Members Posts: 38 Joined: 8-December 12 From: Hudson, OH Member No.: 15,243 Region Association: North East States |
What size bolt is used for the 6 pressure plate bolts for a 914-4. All stock parts.
Mark Henry |
Apr 26 2018, 09:31 PM
I'd have to measure one but it's an M8-1.25 grade 8.8
bdstone914 |
Apr 27 2018, 08:51 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
90007510401 B8 x 15, Hex Head bolt, grade 8.8 minimum.
A longer bolt 20mm bolt will work as it is a through hole in the flywheel. |
AnthonyM |
Apr 27 2018, 01:24 PM
Any washers? Flat, spring or lock. The bolts are 20mm in length.
porschetub |
Apr 27 2018, 04:31 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I used 20mm 8mm HT capscrews and spring washers, already had the capscrews new so used them up,I tend not to reuse the old ones.
Lo-Fi Version | Time is now: 9th June 2024 - 04:59 PM |
