Helicoil experiences?, Oil temp sender cover plate |
Deano |
Jun 8 2005, 11:04 AM
Member Group: Members Posts: 83 Joined: 13-October 04 From: Des Moines, Iowa Member No.: 2,942 |
I have a stripped bolt to my oil temp sender cover plate. I've never used a helicoil before and I am wondering if it would work, or do you need to be able to drill all the way through the stripped hole? If it won't work, any ideas on another fix.
Thanks guys. |
Mike D. |
Jun 8 2005, 11:13 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I would think that there is enough metal there to just tap it and use the net larger size nut. You would have drill the hole the cover plate larger too...
Deano |
Jun 8 2005, 11:26 AM
Yeah, I think you're probably right, probably easier than trying something new with possible bad results. Anyone ever strip one of these? Any further advice?
Mueller |
Jun 8 2005, 11:46 AM
studs would be better than the 2 bolts that hold the plate... |
Deano |
Jun 8 2005, 11:59 AM
Good idea, have you done this?
eg914 |
Jun 8 2005, 10:53 PM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
I stripped the case threads for the temp sender plate bolt. I couldn't stand the thought of two different sized bolts, so I did the helicoil. It wasn't difficult, other than finding the correct metric size, and has held up fine. I found the helicoil at the local Orchard.
SirAndy |
Jun 8 2005, 11:18 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i forgot the exact torque settings for those but it was *really* low ... my advice, i always use the smallest ratchet i can find for those kind of jobs. pretty hard to over-torque with one of those midget ratchets ... also, do *not* re-use the copper crush washers, they need to be replaced ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
Lo-Fi Version | Time is now: 3rd June 2024 - 03:13 AM |
