WTB, L-jetronic injectors |
bob's project |
May 4 2018, 05:54 PM
Newbie Group: Members Posts: 41 Joined: 12-May 11 From: Victoria Member No.: 13,067 Region Association: None |
Hello,
I would like to purchase 2 or more L-jectronic injectors for my 1.8L I am only interested in Bosch / OEM ones Please let me know if you have any available. Thanks in advance. Bob |
ClayPerrine |
May 5 2018, 06:31 AM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I don't think that there are any factory injectors left. But I can make a suggestion. Find 4 injectors from a 1982 Nissan/Datsun 280ZX. They are identical to 912E injectors, and work perfectly in a 914 with L-Jet.
bdstone914 |
May 5 2018, 07:35 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have a few used untested L jet injectors. $10 each. I can test them for actuation. If you go the used route get at least four, have all of ours sent out to cleaned and tested for flow and pattern. Take the four closest matching ones based on flow. Or if you can find new 280ZX injectors replace yours with a set of four.
Are you in Australia? Your access to injector servicing companies may be more limited than what we have in the states. If you are interested I could send out what I have for testing and cleaning. |
bob's project |
May 5 2018, 11:37 AM
Thanks for the reply and suggestion Clay. The 280 injectors seem to be just as uncommon in my area. The only new ones seem to be from standard motor products which I'd rather not use.
bob's project |
May 24 2018, 03:38 PM
Still in need. Please let me know if you have any available.
Thanks, Bob |
mtndawg |
May 24 2018, 05:00 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
You might be able to have them reconditioned by these guys, or maybe they have a set?
http://fuelinjectioncorp.com/ |
914Sixer |
May 25 2018, 07:35 AM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
There is a couple over on theSamba.com $75 each NOS Bosch. Pull up fuel injectors under search.
Lo-Fi Version | Time is now: 10th June 2024 - 01:05 AM |
