F/S 1970-1971 ignition switch with column., These are hard to find. |
porscheaddic |
May 4 2018, 09:29 PM
Member Group: Members Posts: 68 Joined: 9-July 07 From: california Member No.: 7,898 |
Selling this 1970-1971 Porsche 914 steering column with ignition switch. They key turns a d functions properly. Missing turn signal arm. Asking $200 plus shipping.
Thanks Attached image(s) |
JeffBowlsby |
May 5 2018, 08:04 AM
914 Wiring Harnesses Group: Members Posts: 8,535 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I could be interested if its 12 pin connector was not cut off. Or is this the later 1971 version with a 14 pin connector?
porscheaddic |
May 5 2018, 02:23 PM
Jeff,
Not sure if this is a 1970 or 1971? Are the two years interchangeable? Thanks |
JeffBowlsby |
May 6 2018, 09:14 AM
70-early 71 are 12 pin. Late 71 is 14 pin. The two are not interchangeable. Without the connector the internal wiring is useless, all that is left is the case. Too bad the connector was cut off, it simply could have been disconnected.
Lo-Fi Version | Time is now: 10th June 2024 - 02:15 PM |
