123 |
123 |
DAX |
May 6 2018, 07:36 PM
Newbie Group: Members Posts: 11 Joined: 5-April 10 From: CALIFORNIA Member No.: 11,564 Region Association: Central California |
I am replacing my Distributor # 0 231 174 011 with a 123, there are two setting for this distributor #2 and B so which one do I use. can someone help me out
914_teener |
May 6 2018, 09:04 PM
914 Guru Group: Members Posts: 5,201 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
There was a thread on this and a group buy a while back.
If you bought it yourself, I'd check the manual to what ever dizzy you bought for which application you are running, ie, stock FI or carbs ect. So can't help you not knowing that info. All the setup info is on their website including the pdf manual on the settings to use. |
mgphoto |
May 7 2018, 09:24 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
McMark |
May 7 2018, 10:44 AM
This should answer all the questions if you actually take the time to read through...
http://www.914world.com/bbs2/index.php?showtopic=318153 |
rhodyguy |
May 7 2018, 06:57 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
This thread might warrent placement in the 'Lapuwali'/classic thread forum. Easy to find when in a tight spot. Isn't the 123 manufacturer located in GB?
Mblizzard |
May 8 2018, 02:41 PM
The only difference in them is that the "B" gives you 10 degrees negative advance.
I think the negative was for idle conditions to help with emissions. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:40 PM |
