Holes in my car! What is this one for? And where did those others go? |
jcd914 |
May 9 2018, 12:22 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Two questions!
1st: There is a hole behind the dash and I don't know what it is for. In the picture below there are two large holes, one has the remains of a grommet and I believe it is for the fresh air and heat control cables. What is the other hole for? 2nd: It appears the body shop that painted my car filled in the holes in the windshield frame that hold the clips for the trim. Since the car was painted before I owned it I don't know if they were filled on purpose or out of ignorance. I want to use the metal trim so I need the clips. Thoughts? Thanks Jim |
914Sixer |
May 9 2018, 06:27 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Top hole is for water lines for windshield washer. Holes for windshield clips might be tricky. Get someone with the windshield out to measure the holes for you.
ClayPerrine |
May 9 2018, 06:43 AM
Life's been good to me so far..... Group: Admin Posts: 15,502 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Lo-Fi Version | Time is now: 1st June 2024 - 04:44 PM |
