Ed Evans |
Newbie ![]() Group: Members Posts: 12 Joined: 15-August 17 From: Idaho Member No.: 21,348 Region Association: None ![]() |
Is there a preferred (non destructive) method to remove the dust sealing cap that goes over the headlight pushrod?
second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
Is there a preferred (non destructive) method to remove the dust sealing cap that goes over the headlight pushrod? ![]() I can't get mine on!! I would spray with WD-40 or anything slippery like dish soap or anything and drench the entire boot with a sponge for a while....the boot will slowly loosen without damage if you baby it..... gg |
PlantMan |
Member ![]() ![]() Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California ![]() |
I pushed mine out with a large blade of a flat head screw driver. Have to wedge the rubber flange out from inside of the bucket pushing outside.
No damage was done to the boot by doing this. |
Ed Evans |
I pushed mine out with a large blade of a flat head screw driver. Have to wedge the rubber flange out from inside of the bucket pushing outside. No damage was done to the boot by doing this. This worked for me also. After pushing through from the bucket side I was able to peel the boot up from the bottom side near the round relay. Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 19th July 2025 - 03:28 AM |
